albert.ho
Community Member
I am look for config an 1250AP (AIR-LAP1252AG-C-K9) to Join in a 5508 wireless cotroller. When the AP first time join in, I can see the AP in the WLC. But a couple of sec, the AP will lose in the WLC. I checked console in the AP. I cannot type anything in the AP console.
The join log in the WLC is "mage data request received from an unsupported AP"
What's wrong of the AP or Wireless controller ?
This is the DHCP setting in default gateway
ip dhcp pool dhcp107
   network 148.164.107.0 255.255.255.0
   default-router 148.164.107.254
   option 43 hex f104.94a4.6dbc
   option 60 ascii "Cisco AP c1250"
   dns-server 148.164.52.153
   lease 364
This is the WLC setting
System Inventory
NAME: "Chassis"    , DESCR: "Cisco Wireless Controller"
PID: AIR-CT5508-K9,  VID: V01,  SN: FCW1412L0G6
Burned-in MAC Address............................ 88:43:E1:63:12:00
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 25
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.98.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... N/A
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... asch-han5538-wlc
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 148.164.107.220
Last Reset....................................... Software reset
System Up Time................................... 0 days 1 hrs 35 mins 27 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... CN  - China
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
External Temperature............................. +23 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 0
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Network Information
RF-Network Name............................. SSCI
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Enable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Unicast
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Enabled
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
IP/MAC Addr Binding Check .................. Enabled
