TCC_2
Level 10
Level 10
Core Issue
This problem is sometimes caused by these issues:
  • A problem with the power source
  • A hardware problem
  • A mis-reported watchdog timeout
Resolution
If the show version command output displays restarted by power-on, it usually means that the router was either power-cycled, or the power source went down for a few seconds.
In order to resolve this issue, verify the power source and move the router to a different circuit if possible. If this does not resolve the problem, replace the power supply or chassis. For the Cisco 7200 series router and uBR 7200 series routers, a reload due to a power on can be caused by a mis-reported watchdog timeout. If a watchdog timeout is suspected, refer to the appropriate Field Notices.
Refer to Troubleshooting Watchdog Timeouts for more information about watchdog timeouts.
