Jeffrey Keown
Reference:
CSCuj13043    Controller 7500 W/ version 7.6.1.72 crashed, Task: reaperWatcher
Power off the 7510.
Connect a PC monitor via VGA cable and USB keyboard to the front panel connections:
Power on the 7510.  Confirm that output is visible on the monitor.
After approximately 4 minues from power on, the following Bios Menu will display.  Press F1 to enter setup.
This screen is displayed for about 5 seconds.  If you miss pressing F1 in time, power cycle the 7510 to start over.
Refer to the following sequence to check Hyperthreading status, disable if necessary, then save and exit:
Select Processor:
Select Hyperthreading:
Select Disable:
Select Save Settings:
Select Exit Setup:
Press Y:
