TCC_2
Level 10
Level 10
Core issue
Failure to configure a telnet password on an IOS-based switch results in the password required but not set message being displayed when attempting to Telnet into the switch.
This applies to any Cisco device running Cisco IOS , whether Telnetting to a router feature card or module running Cisco IOS within a chassis that has a supervisor running CatOS, a separate router running Cisco IOS, or a Catalyst 4000/4500 or 6000/6500 family member running in Integrated mode (Cisco IOS that replaces CatOS). This does not apply to CatOS.
Resolution
The password required but not set message indicates that a telnet password needs to be configured on the switch. This is done by issuing the following commands through the switch console:
switch> enable
switch# config t
switch(config)# line vty 0 4
switch(config-line)# password
switch(config-line)# exit
switch(config)# exit
switch# write mem
After this configuration is done, a password prompt should come up when Telnetting into the switch.
CompassIntl
Community Member
When I attempted to use the above command series, it balked at using the password command with no value...
Therefore, I would recommend a note that when you execute the above series you supply the new password value.
G
>>>   My Switch Info   >>>
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA10a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 24-Jul-07 17:13 by antonino
Image text-base: 0x80010000, data-base: 0x80570000
