Madhuri C
Introduction
Autonomous AP and Bridge Basic Configuration Template
Configuration Example
Configuring an IOS AP
1. Creating an SSID
AP#
  Configure terminal
  Dot11 ssid <ssid_name>
   Authentication open
   Guest-mode                                               <--- To broadcast the SSID
2. Configuring AP as a DHCP server
AP#
Configure terminal
  Ip dhcp excluded-address                         <---List of IP addresses to be excluded>
  Ip dhcp pool <pool name>
    Network <network id> <mask>
    Default-router <IP address>
3. Configuring radio interface
Configure terminal
Int dot11radio0  or  Intdot11radio1
    Ssid <ssid_name>                                    <--- Map the SSID to radio interface
    Station-role root
    bridge-group
    no shut
4. Configuring Ethernet interface
interface FastEthernet0
  bridge-group 1
5. Configure the BVI interface
interface BVI1
ip address <ip address> <mask>
6.
6. Specify the default gateway
  ip default-gateway <ip_address>
7. Configuring  radio sub interfaces
If there are multiple vlans(For ex,vlans 1,2,3 in this case), configure one of the vlan to be native depending on your network/switchport config and map it to bridge-group 1
Conf t
interface Dot11Radio0.1
  encapsulation dot1Q 1 native
  bridge-group 1
interface Dot11Radio0.2
encapsulation dot1Q 2
  bridge-group 2
interface Dot11Radio0.3
encapsulation dot1Q 3
  bridge-group 3
8. Configuring fa sub interfaces for multiple vlans
interface fa0.1
  bridge-group 1
interface fa0.2
  bridge-group 2
interface fa0.3
  bridge-group 3
9. Enabling mbssid if multiple ssids needs to be broadcast
Interface dot11 0
  Mbssid
Mbssid guest-mode
10. SSID and vlan mapping for multiplevlans/ssids
Conf t
  Dot11 ssid <ssid1>
  Vlan 1
Dot11 ssid <ssid2>
Vlan 2
11. Speed, channel and power settings
Conf t
Int dot11 0
Speed range  or Speed throughput
Power local max
Or
Powerlocal cck max
Powerlocal ofdm max
Channel <number> or <least-congested>
12. Enabling http and https to access GUI
Conft
ip http server
ip http secure-server
ip http authentication local
13. WEP configuration
Configuration if there are multiplevlans and if SSIDs are mapped to vlans:
Conf t
      encryption vlan <id> mode wepmandatory
encryption vlan <id> key<slot> size 128bit 0 <encryption key> transmit-key
or
Configuration if there is a single vlans and if SSID is notmapped to vlan explicitly”
Conf t
       encryptionmode wep mandatory
encryption key <slot> size 40bit 0 <encryption key> transmit-key
14. WPA1 configuration
Configure terminal
interface dot11Radio 0
    encryption vlan <id> modeciphers tkip
     (or )
    encryption mode ciphers tkip               <--- Configuration if SSID is not mapped to vlans explicitly
exit
dot11 ssid <ssid_name>
authentication open
  authentication key-management wpa
  wpa-psk ascii <Enter pre-shared_key>
15.  WPA2 configuration
Configure terminal
  encryption vlan <id> mode ciphers aes-ccm
  (or)
  encryption mode ciphers aes-ccm           <--- Configuraton if SSID is not mapped to vlans explicitly
exit
authentication open
  authentication key-management wpa version 2
16. Configuration on switchport
switchport mode trunk
switchport trunk native vlan 1
switchport trunk allowed vlan 1,2,3
Bridge Configuration
Unlike APs, bridges would have a single SSID mapped to native VLAN for bridging. The SSID, Encryption, Authentication on root and non root bridges should match.
1. Configuration Root bridge
dot11 ssid bridging
   vlan 1
   infrastructure-ssid                     <--- Use infrastructure-ssid optional ifwireless clients are to be connected too
int dot11 0
station-role root bridge
or
station-role root bridge wireless-clients               <--- Bridging and allow client association too
interfaceDot11Radio0.1
bridge-group 1
interfaceDot11Radio0.2
bridge-group 2
interfaceFastEthernet0.1
bridge-group 1
interfaceFastEthernet0.2
bridge-group 2
2.  Configurationon Non Root bridge
dot11 ssid bridging
   vlan 1
   infrastructure-ssid
int dot11 0
station-role non-root bridge
(or)
station-role non-root bridge wireless-clients                <--- Bridging and allow client association too
bridge-group 1
bridge-group 2
bridge-group 1
bridge-group 2
Useful commands
-  ‘Show dot11 associations all’ to check details of associated clients.
-   ‘Show controllers dot11 0’ to check the current channel,current and available power values, number of mbssids.
-   ‘Dot11 dot11radio 0 carrier busy and show dot11 carrier busy’ shows the interference percentage for every channel which can be used to select the channel with least interference.
Useful links
Vlans on APs and bridges
Complete configuration guide of AP
Configuration Examples and TechNotes
Vinay Sharma
Level 8
Level 8
Madhuri great information. thanks for sharing and keep it up
pjhingra
Community Member
Excellent documentation. Pls add a network diagram for completeness.
greylingch
Community Member
Thank you for being awesome !
vitor.oliveira1
Community Member
Are you using telnet?
louhutchinson
Community Member
Wireless Bridging Diagram:
AP1 <===> AP2
brianalster
Frequent Visitor
Frequent Visitor
Not sure if anyone is still monitoring this, but....
There are a few references in this document to bridge-groups 2 & 3, however, I do not see where they are ever applied to an interface (like bridge-group 1 is to Gig0 is in section 4).  Can someone explain how the different bridge-groups are implemented and why?  I am trying to set up a point to multi-point wireless connection and I'm wondering if I need to configure bridge-groups for each remote building (i.e. bridge-group 2 vlans would be directed to building #2 and bridge-group 3 vlans would be directed to building #3, etc.)  I'm just not understanding how the bridge-groups in the configuration example are supposed to function.
