TCC_2
Level 10
Level 10
Core Issue
In many cases, the Border Gateway Protocol (BGP) best path algorithm is not completely understood, resulting in an incorrect judgement that BGP is not selecting the best path to place in the routing table.
Resolution
BGP routers typically receives multiple paths to the same destination. The BGP best path algorithm decides which is the best path to install in the IP routing table and to use for forwarding traffic.
Assume that all received paths for a particular prefix are arranged in a list, similar to the output of the show ip bgp [longer-prefixes] command. Some paths received by the router are not considered candidates for the best path. Such paths typically do not have the valid flag in the output of the show ip bgp [longer-prefixes] command.
In order to understand how BGP selects the best path (out of multiple paths) to the same prefix, refer to BGP Best Path Selection Algorithm.
