on 10-13-2022 05:56 AM
Download BGP Routing Protocol With 16 Practice Labs.
Table of Contents
Lab 1: MED and AS-Path Prepend
Lab 2: BGP Local Preference
Lab 3: BGP path control
Lab 4: BGP Confederations
Lab 5: Bestpath as-path ignore and aggregate-address
Lab 6: Community Attribute AS-Path Prepend and Default route
Lab 7: BGP Backdoor and AS-Path Prepend
Lab 8: AS-Path Prepend Weight and Default route
Lab 9: Community Attribute and Route Reflector
Lab 10: BGP Peer Group Community Attribute and Local Preference
Lab 11: MP-BGP Local Preference Weight and Community Attribute
Lab 12: MP-BGP OSPFv3 and Attributes Manipulation
Lab 13: BGP Confederation weight and Unsuppress-map
Lab 14: BGP Conditional advertisement
Lab 15: Route Aggregation Attribute-map and Advertise-map
Lab 16: BGP ORF (Outbound Route Filtering) capability
thanks; any chance to get pre-config files ?
Hi @Martin L at the top of each lab you the basic configuration of all routers so that you can copy and past.
what IOS version(s) have you used for this lab ?
Any chances that BGP behavior/commands may vary between IOS'es ?
thanks
Regards, ML
**Please Rate All Helpful Responses **
Use router IOS 15.X.
Helping
Just wanted to say thank you.
Just completed the first two labs. Great work. Labs are organized, easier to follow than a lot of the pay labs I have seen. Great explanations. Thanks for the hard work you put into this doc.
@twmoody You are welcome, I am happy to see that the labs are helpful..
These are awesome labs!!!
@trevorc1653 You are welcome...
hi @Meddane ,
I am starting on these labs today and pretty excited. I finished the other ones on redistribution and suboptimal routing yesterday night.
From the bottom of my heart, I just want to say thank you. Your labs are really helping me understand alot practically!
BR,
Hi @Meddane,
Thank you so much for sharing this LAB, just right on time due going to review my BGP routing knowledge (i.e. go through Cisco U e-learning, read the e-book and do LAB practice) and got 5 units of ISR1100-4GLTE that just recently migrated to IOS-XE 17.9.8 as autonomous.
