10-31-2022 03:51 PM - edited 10-31-2022 04:31 PM
When ZTP fails, the reason is always listed on the Plug and Play Connect Portal (software.cisco.com). One can click on the "Show Log..." drop-down for their device to see the latest error messages shown in the screenshot.
If the logs suggest the issue originates from the device or is not sufficiently detailed, the only other debugging option is to access the root shell of the device and open the log file called /var/log/pnp/pnp.log. This will indicate failures from the device's PnP agent context instead of the PnP server context. In this case, you must contact our Cisco Technical Assistance Center: Technical support team for Cisco customers.
Yes, if the device cannot reliably ping devicehelper.cisco.com (the PnP Connect Server), then ZTP is not possible. Failure to connect could be due to various modem-related reasons, such as an invalid SIM card, bad signal strength, or incorrect modem settings preventing the modem from attaching to the network. Note that even if ping to devicehelper.cisco.com works, it is still possible that the connection is not reliable enough (bad signal quality). Therefore, it is best to check for the cellular signal strength and ensure its quality using the 'show cellular 1 radio' CLI.
You can manually configure the device at any time instead of going through the PnP/ZTP process. The PnP/ZTP process is primarily for convenient, automated deployment but does not actually prevent the device from being used as advertised.
If you can't use ZTP for some reason, one can manually configure all the control connection parameters as below. Please note that the organization name, system IP, vbond, and site ID information will have to correspond to the deployment. For example, you should change the organization-name to match the deployed organization name, the system-ip to be unique on the network, the vbond IP address needs to match the actual vBond address, and the site-id should also be unique.
Below is just a sample that you should replace with the appropriate values.
config terminal
viptela-system:system
sp-organization-name "CG-LTE-Test"
system-ip 1.1.1.120
vbond 13.50.70.148 port 12346
site-id 320
domain-id 1
commit
gw-system:interface Cellular1
tunnel-interface
no border
color private1
no last-resort-circuit
no low-bandwidth-link
max-control-connections 2
no vbond-as-stun-server
vmanage-connection-preference 8
port-hop
carrier default
nat-refresh-interval 5
hello-interval 1000
hello-tolerance 12
allow-service all
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service sshd
no allow-service netconf
no allow-service ntp
no allow-service ospf
no allow-service stun
allow-service https
no allow-service snmp
no allow-service bfd
encapsulation ipsec weight 1
commit
end
Furthermore, you need to install the root certificate:
CellularGateway# request root-cert-chain install /flash/root-ca.crt
The file root-ca.crt (name does not matter, it can be some other name) is the Enterprise Root CA certificate file that should have been already generated for the deployment. For example, it should match the file on the vBond/vManage controllers. Since without ZTP, you need to manually copy it to the device's /flash storage, you will need to set up a TFTP server to the device and download it to the CG418-E/CG522-E.
CellularGateway# gw-action:request file download tftpip <tftp ip address> filename root-ca.crt
This will store the root-ca.crt from the TFTP server to the device's /flash partition.
The ‘show control connections’ CLI will show the control connections to both vBond and vManage at any point in time.
When the control connection first begins to establish (as soon as all the correct configs and certificates are in place on the device, either through PnP or manually), the device will first reach out to the vBond orchestrator.
This means the output of this CLI will show only a vBond peer entry along with a STATE such as ‘connect’ or ‘challenge’.
The final, correct output when the device is connected to vManage, is just a single peer entry for vManage:
CellularGateway# show control connections
PEER PEER CONTROLLER
PEER PEER PEER SITE DOMAIN PEER PRIV PEER PUB GROUP
TYPE PROT SYSTEM IP ID ID PRIVATE IP PORT PUBLIC IP PORT ORGANIZATION LOCAL COLOR PROXY STATE UPTIME ID
vmanage dtls 1.1.1.4 4294964286 0 10.0.2.60 12346 13.50.168.216 12346 spaal-LTE-Test private1 No up 0:01:20:45 0
If there is any vBond entry that remains after more than approximately 5 minutes, then the device is likely still in the process of connecting and has not yet disconnected from the vBond. Depending on the STATE (‘connect’, ‘challenge’), this could either mean the control connection has not yet finished due to many potential reasons:
If the output is completely empty, then either the control connection configs/certificate are not present (the most common reason) or, in rare cases, the device requires a restart.
The ‘show control local-properties’ CLI presents the current relevant information needed for the control connection, such as the configured system parameters and certificate validity/installation status. It has a lot of overlap with ‘show running-config’ except it also shows additional Root CA certificate information. Below is a valid working output:
Note that the root-ca-chain-status should say ‘Installed’, the certificate-not-valid-after should be a valid date and match the Root CA validity, and the configured system properties should be listed here as well.
CellularGateway# show control local-properties
personality vedge
sp-organization-name CG-LTE-Test
root-ca-chain-status Installed
certificate-status Installed
certificate-validity Valid
certificate-not-valid-before Mar 21 08:17:09 2020 GMT
certificate-not-valid-after Aug 09 20:58:26 2099 GMT
enterprise-cert-status Not-Applicable
enterprise-cert-validity Not Applicable
enterprise-cert-not-valid-before Not Applicable
enterprise-cert-not-valid-after Not Applicable
dns-name vbond-dev-xxxxxx.viptela.info
site-id 320
domain-id 1
protocol dtls
tls-port 0
system-ip 1.1.1.120
chassis-num/unique-id CG418-E-XXXXXXXXXXX
serial-num XXXXXXXX
subject-serial-num XXXXXXXXXXX
enterprise-serial-num No certificate installed
token Invalid
keygen-interval 1:00:00:00
retry-interval 0:00:00:15
no-activity-exp-interval 0:00:00:20
dns-cache-ttl 0:00:02:00
port-hopped FALSE
time-since-last-port-hop 0:00:00:00
embargo-check success
number-vbond-peers 0
number-active-wan-interfaces 1
NAT TYPE: E -- indicates End-point independent mapping
A -- indicates Address-port dependent mapping
N -- indicates Not learned
Note: Requires minimum two vbonds to learn the NAT type
INTERFACE PUBLIC PUBLIC PRIVATE PRIVATE PRIVATE VS/VM COLOR
IPv4 PORT IPv4 IPv6 PORT
srcr2 174.194.132.195 4602 192.168.1.1 :: 12346 0/1 private1
STATE MAX RESTRICT/ LR/LB LAST SPI TIME NAT VM
CNTRL CONTROL/ CONNECTION REMAINING TYPE CON
STUN PRF
up 2 no/yes/no No/No 0:01:29:15 0:00:00:00 N 5
The “show control connections-history” CLI will show the latest status in establishing the control connection if any. The output also comes with a table to indicate what the errors/status in each entry mean. For example, the below table shows a single entry that simply shows that the vBond was disconnected, which is the correct behavior after establishing the control connection to vManage.
CRTVERFL - Root cert invalid. Either it is not installed, or the device system time is factually incorrect.
DCONFAIL - Cannot ping the vBond. Check the cellular connection quality/reachability.
CellularGateway# show control connections-history
PEER PEER PEER SITE DOMAIN PEER PEER PEER
TYPE PROTOCOL SYSTEM ID ID PRIVATE IP PRIVATE PUBLIC
IP PORT IP
vbond dtls 0.0.0.0 0 0 13.50.70.148 12346 13.50.70.148
PEER LOCAL STATE LOCAL REMOTE REPEAT DOWNTIME
PUBLIC COLOR ERROR ERROR COUNT
ORGANIZATION
12346 private1 tear_down DISCVBD NOERR 0 2021-11-29T23:01:39+0000
BDSGVERFL |
Board ID Signature Verify Failure |
BIDNTPR |
Board ID not Initialized |
BIDNTVRFD |
Peer Board ID Cert not verified |
BIDSIG |
Board ID signing failure |
CERTEXPRD |
Certificate Expired |
CRTREJSER |
Challenge response rejected by peer |
CRTVERFL |
Fail to verify Peer Certificate |
CTORGNMMIS |
Certificate Org name mismatch |
DCONFAIL |
DTLS connection failure |
DEVALC |
Device memory Alloc failures |
DHSTMO |
DTLS HandShake Timeout |
DISCVBD |
Disconnect vBond after register reply |
DISTLOC |
TLOC Disabled |
DUPCLHELO |
Recd a Dup Client Hello, Reset Gl Peer |
DUPSER |
Duplicate Serial Number |
DUPSYSIPDEL |
Duplicate System IP |
HAFAIL |
SSL Handshake failure |
IP_TOS |
Socket Options failure |
LISFD |
Listener Socket FD Error |
MGRTBLCKD |
Migration blocked Wait for local TMO |
MEMALCFL |
Memory Allocation Failure |
NOACTVB |
No Active vBond found to connect |
NOERR |
No Error |
NOSLPRCRT |
Unable to get peer's certificate |
NEWVBNOVMNG |
New vBond with no vMng connections |
NTPRVMINT |
Not preferred interface to vManage |
HWCERTREN |
Hardware vEdge Enterprise Cert Renewed |
NOZTPEN |
No/Bad chassis |
OPERDOWN |
Interface went oper down. |
ORPTMO |
Server's peer timed out. |
RMGSPR |
Remove Global saved peer. |
RXTRDWN |
Received Teardown. |
RDSIGFBD |
Read Signature from Board ID failed. |
SERNTPRES |
Serial Number not present. |
SSLNFAIL |
Failure to create new SSL context. |
STNMODETD |
Teardown extra vBond in STUN server mode. |
SYSIPCHNG |
System |
SYSPRCH |
System property changed |
TMRALC |
Timer Object Memory Failure. |
TUNALC |
Tunnel Object Memory Failure. |
TXCHTOBD |
Failed to send challenge to BoardID. |
UNMSGBDRG |
Unknown Message type or Bad Register msg. |
UNAUTHEL |
Recd Hello from Unauthenticated peer. |
VBDEST |
vDaemon process terminated. |
VECRTREV |
vEdge Certification revoked. |
VSCRTREV |
vSmart Certificate revoked. |
VB_TMO |
Peer vBond Timed out. |
VM_TMO |
Peer vManage Timed out. |
VP_TMO |
Peer vEdge Timed out. |
VS_TMO |
Peer vSmart Timed out. |
XTVMTRDN |
Teardown extra vManage. |
XTVSTRDN |
Teardown extra vSmart. |
STENTRY |
Delete same tloc stale entry. |
HWCERTREV |
Hardware vEdge Enterprise Cert Revoked. |
The update process is the same as the initial manual installation process.
Usually, the best way to debug vDaemon is through these commands:
show control affinity config/status
show control connections-info
show control statistics
show control summary
show control valid-vmanage-id
show control valid-vsmarts
Since these outputs are a very reliable indicator of vDaemon’s current status and the data it is currently operating on.
It can potentially be helpful to turn on the following debugs
For certificates, challenge verification during hello packet exchange, and other miscellaneous information:
CellularGateway# debug vdaemon misc high
For confd-related information surrounding the vdaemon subscription/callbacks (such as system configs):
CellularGateway# debug vdaemon confd high
Technically, it is possible to set maximum debugs using:
CellularGateway# debug vdaemon all high
But since this will output a flood of hello control messages, please do not do so without also setting:
CellularGateway# debug vdaemon hello low
No. There is no packet capture capability on the Cellular Gateway devices currently.
If a template push fails, if the vManage GUI itself does not already indicate the offending config, collect an Admin-Tech in an SD-WAN Environment and Upload It to a TAC Case. Navigate to Tools -> Operational Commands. Click on Generate Admin Tech for vManage.
Include all three available options on the screen and click Generate.
Click 'Show Admin Tech List' as shown in the image. It will take a couple of minutes to generate the logs.
Click the 'Download' icon.
Download admin tech logs from the local system and upload them to a Service Request (SR).
The device logs may not be helpful in this scenario because the configs may not have reached the device yet due to the template push failure.
Please also check with vManage experts for advanced template push debugging.
