bkoryus
I've got a new C819HG+7-K9 router and have installed two active SIM cards (LTE) in it.  However, when I try to enable encapsulation ppp on the cellular card I'm getting an error that Cellular0: Only SLIP encapsulation supported.  Any suggestions?
EVDO-#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
EVDO-(config)#int cel0
EVDO-(config-if)#en
EVDO-(config-if)#encapsulation ppp
EVDO-(config-if)#
Bob
firestormnet
Hi Bob.
Yes, that's right. There is no ppp, only slip encapsulation on cellular interface.
Just change a chat-script and it should work. Use cisco reference:
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwls_hspa.html#wp1527716
Not applicable
I tried chat-script gsm "" "ATDT*98*3#" TIMEOUT 30 "CONNECT" and
chat-script gsm "" "AT!SCACT=1,3" TIMEOUT 60 "OK" but I still get the same error. Do you have any idea of what it could be?
