I need a router doing simple SNAT. There will be around 500 to 2000 users behind the device. What NAT performance can be expected?
Btw, there will be no additional service running, so simple SNAT, no ACL, no firewall.
thanks in advance
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Since you entered you question as a document, unable to attach Cisco source document, but Cisco notes 2921 PAT performance as 138 Mbps for a 2921 (@ 75% CPU load).
Latchum Naidu
I would suggest a 2951 is the best to handle the mentioned user count.
We have nearly 2000 above user pc's for which all the NAT performing by the 2951 router (two in hsrp mode).
The CPU is constant between 20 to 30% (spikes up to 60%)
Please rate the helpfull posts.
Naidu.
