Ciro G Mele
Level 2
Level 2
Configuring an interface in bdi mode in an asr 920, at the end of the configuration the cpu goes to 90 percent and does not go down.
How can this be solved, has this happened to anyone with this type of equipment?
Thank you.
knejman
Hi Ciro,
That sounds interesting.  Would you be able to share the configuration you're making just prior to the CPU spike, as well as the top processes consuming CPU after the configuration is made?  You can run 'show process cpu sorted | ex 0.00%' during the CPU spike to capture this.
Cheers!
can you reduce MTU, it can the MTU fragment make this high CPU spike.
Ciro G Mele
Level 2
Level 2
Hi again,
interface GigabitEthernet0/0/2
 description LAN Min.Asu.Agra(P8)
 no ip address
 negotiation auto
 mpls ip
 cdp enable
 service instance trunk 2 ethernet
  encapsulation dot1q 801-803   ---only 3 vlans---
  rewrite ingress tag pop 1 symmetric
  bridge-domain from-encapsulation
¡¡ Thanks a lot !!
Ciro G Mele
Level 2
Level 2
Hi MHM
in the three interfaces there is no mtu defined
interface BDI801
ip vrf forwarding red_legacy
ip address X.X.X.X 255.255.255.0
mpls ip
interface BDI802
mpls ip
interface BDI803
mpls ip
Thanks.
rajayousaf1402
I have a issue regarding rsp card is access on the console
Rsp card is not booting and shot when I insert the card in slot .
