rjain5
Cisco Catalyst 8000V Edge software virtual router is now available to customers in select AWS Local Zones.
Extend your SD-WAN fabric into your AWS Local Zones. You can use Cisco Catalyst 8000V Edge software virtual router in AWS Local Zones similar to other AWS regions and availability zones.
Traditional routing use cases such as NAT and VPN termination are also enabled while preserving the low-latency benefits of AWS Local Zones. See "Deploying Cisco Catalyst 8000V in AWS Local Zones" article for more information.
Launch details:
  • Which AWS Local Zones?
    • All where c5.2xlarge and c5d.2xlarge instances are available.
  • Which AWS EC2 Instance types?
    • c5d.2xlarge instances in AWS Local Zones in US, and
    • c5.2xlarge instances in AWS Local Zones outside the US.
  • What version of Catalyst 8000V?
    • IOS XE 17.12.2 or later.
  • What license consumption model?
    • “Bring your own license” (BYOL) licensing model.
Contact your local Cisco Sales team to discuss your unique needs.
References:
