kyukim
You can learn basic configuration and troubleshooting for Cisco IOS DNS/DHCP.
Kyuhwan Kim.
Mark Bracking
Configure DHCP option 81 FQDN
Can you explain this section further?
Say you want to add your router to the infrastructure by making an AD object adding it through routing and access on you windows server? what is the order of steps to complete this process on the router?
thanks for taking the time to put this together and post it. I find it kind a hard to believe that you have had this up for 5 years and no one committed on it. Great Job
Philip D'Ath
Hi brackingmr  .  I think you missed this critical bit:
I wouldn‟t much care this as IOS DHCP can‟t update windows AD DNS
Philip D'Ath
Good article @kyukim.  I think IOS DNS views in particular are underused.  They are very powerfull.
