Nael Mohammad
Level 5
Level 5
The following is assumed you are an administrator  or have superuser privlages on the server.
1. The first step is to create a file called "local.superusers" in the folder "<CNR_INSTALL_PATH>/conf/priv" .
  • Solaris:
    • /opt/nwreg2/local/conf/priv
  • Windows:
    • C:\Program Files\Network Registrar\local\conf\priv
2. In the local.superusers file, add the following entry using any text editor :
  • tempadmin changme
    • The format is "username password" in the text file and needs to be on the same line.
3. Go to http://<servername>:8080 ---> administration --> administrator, update credentials accordingly.
rehernandez
Today in 2021, this help me to recover WebUI password!
!!!!Thank you!!!!
raul-chairez
It works fine, thanks!!!
