tahuja
Cisco SD-WAN Cloud OnRamp allows you to simplify and secure connectivity to cloud applications and public cloud. Interested in testing out the latest Cisco Cloud OnRamp solutions?
The following use cases are implemented as Sandbox:
  • AWS: Cloud on Ramp for Multicloud on AWS including TGW and c8000v virtual cloud gateway creation
  • GCP:  Cloud on Ramp for Multicloud on GCP using Google Network Connectivity Center
  • Azure: Cloud onRamp for Multicloud on Azure with vWAN
AWS Use Case: please visit dcloud.cisco.com and search for "Cisco Catalyst SD-WAN v20.9 Multicloud OnRamp - Bring Your Own Cloud Account v1". dCloud is Cisco demo platform with hundreds of different labs and demos, which are free of charge for Cisco customers and partners. Ask your local Cisco Team for access to dCloud. Your local Cisco Team is also able to reserve the Sandbox lab and share it with you directly.
Azure Use Case: please visit dcloud.cisco.com and search for "Cisco Catalyst SD-WAN v20.9 Multicloud OnRamp - Bring Your Own Cloud Account v1". dCloud is Cisco demo platform with hundreds of different labs and demos, which are free of charge for Cisco customers and partners. Ask your local Cisco Team for access to dCloud. Your local Cisco Team is also able to reserve the Sandbox lab and share it with you directly.
GCP - please visit https://www.cloudskillsboost.google/catalog_lab/6676 and start Google Cloud Self-Paced Lab "Connecting Cisco SD-WAN to Google Cloud using Cloud onRamp Automation".
donghx
In the Guide-Azure_Sandbox, it seems setting up the expectation to demo full CoR for Azure integration with S2S use case as indicated in Figure 1 Integration. Then in actual sandbox setup, it only shows CoR Azure capability for S2C use case. Is the S2S integration not ready or not fully automated yet?
the submit button is broken , can someone please fix this
