suntongmengmo
Community Member
I've got a 2960-8tc-l switch that I need to connect via multi-mode fiber to a Hirschmann switch.The hirschmann switch supports only 100M bits fibber and the vavelength is 1310nm. So I should choose  SFP module (GLC-FE-100FX) or SFP module (GLC-LH-SM) or both can't be connetet to a hirschmann switch? Is there any other solution if both can't be connected to a hirschmann switch except for replacing the cisco switch?
Looking for a solution that will quickly resolve this problem!
Thank you!
ScottAgen00860
Is a Hirshmann GRS1042 compatible via multimode fiber with Cisco WS-C3850-24XS
Rich R
@ScottAgen00860 as long as you use compatible equivalent SFP's on each end of the fibre it will work.
You can select the GRS1042 SFP from the Accessories list on page 73 of http://www.doc.hirschmann.com/pdf/IG_GRS_1042-1142_05-0218_en_2018-02-13.pdf
You can select the 3850 SFP from https://tmgmatrix.cisco.com/?npid=403
ScottAgen00860
Thank you Rich R
