Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Campus Manager in LMS 3.1 tries to force the user to install an outdated Java Plug-in ver 1.5.0_13. How does one disable this forced check? If an end user can't try it with a recent version of Java, this component is useless anyway.
It should not install Java Plug-in 1.5.0_13 version as you said it is a older version. If you are the LMS customer and face this issue still, you can raise a TAC case at
I did open a TAC case. Cisco only supports one specific version of Java for Topology Services. Any other version installed will redirect you to the Java Plug-in download page. This is very unfortunate, as soon as a vulnerability is announced and patched, you will be unable to use this feature. You can't launch the app unless you have the exact version of Java they expect.
