ashu_genius
Community Member
Hi guys
i want to know is there is any command which i used to clear the console messages from router terminal just like cls command  in windows
johnnylingo
Level 9
Level 9
The messages are appear on your terminal program, not the router itself.   Just clear your screen or restart the terminal program.
To clear the internal buffer, use "clear log"
johnlloyd_13
Level 11
Level 11
if you're directly connected to the router or switch device, just do a "no terminal monitor" to disable console message or logs.
PETER MARTLAND
Level 2
Level 2
#clear log will delete the logs from the buffers
conf t#no logging console
disables logging on your console session so you dont see lots of messages when you need to work on it.
term no monitor will also disable console messages from a telnet session and term mon enables them.
Mouhanad.alnaif
Community Member
this options does not exist unfortunately on cisco IOS  but you can clear the screen in your terminal window if you use Tera Term go to Edit menu and then you need to choose clear screen.
I think putty and supper-putty also support this option.
