marco.db59
Community Member
Hi all. This is my first post.
I need help to connect an AP wap4410n to a Catalyst 4506 (actually there is a switch between the AP and the Catalyst but, because the behavior is the same, I simplified the scenario for test purposes).
I must broadcast from the AP two SSID on two different VLAN: one for students on a VLAN (116), and another for Faculty staff on a different VLAN (120) with a completely different addressing range.
This is the VLAN configuration for the WAP4410N:
My problem: If I connect the AP to a port on the Catalyst configured to use a single VLAN (either 116 or 120)
interface GigabitEthernet2/18
switchport access vlan 116
no cdp enable
I can configure normally the AP and navigate from client connected (on that VLAN);
however, if I connect the AP on a port configured for more VLAN
switchport trunk allowed vlan 116,120
switchport mode trunk
no cdp enable
I can't configure neither navigate.
What am I doing wrong? what a mistake I'm doing?
PS: I also tried with a Dell AP 2690, similar configuration: same behavior !!
Thanks in advance !!
Marco Di Bonifacio
