- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
09-17-2009 01:18 PM - edited 03-01-2019 04:24 PM
There are many obvious reason to use FTP to upload an image, but the one I'm going to cover is transferring an IOS image across the internet using HTTP. This tutorial will work for FTP as well.
Referring to the image above, we want to upgrade the IOS on RTR-A. We will be accessing the IOS image that is on the web server with the address of b.b.b.2. The command we use is
copy http://b.b.b.2/c3825-advsecurityk9-mz.124-25a.bin flash:
Now is where the fun starts! The first thing you may need to do is disable passive FTP on RTR-A. The default is to use passive FTP.
no ip ftp passive
Next run the copy command from above.
RTR-A#copy http://b.b.b.2/c3825-advsecurityk9-mz.124-25a.bin flash:
Destination filename [c3825-advsecurityk9-mz.124-25a.bin]?
%Error opening http://b.b.b.2/c3825-advsecurityk9-mz.124-25a.bin (I/O error)
Well that's no good. What's going on? Checking the ACL applied to the public interface, we some denied traffic.
057557: Jul 1 12:43:37 CST: %SEC-6-IPACCESSLOGP: list 102 denied tcp b.b.b.2(80) -> a.a.a.2(20651), 1 packet
Ahh, we need to create an ACE to allow the traffic. But take a look at the destination address. In this case it's a.a.a.2 which is the PAT address for internal clients, not the interface IP of a.a.a.1 Add the ACE to the ACL.
permit tcp host b.b.b.2 host a.a.a.2 eq 80
Try the copy again.
Loading http://b.b.b.2/c3825-advsecurityk9-mz.124-25a.bin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
23372352 bytes copied in 344.504 secs (67843 bytes/sec)
Now it's working! Don't forget to verify the image. Directions for that can be found at https://supportforums.cisco.com/docs/DOC-6033
- Mark as Read
- Mark as New
- Bookmark
- Permalink
this method or technique is nice , but if you check from technical perspective point of view its is easy to install and configure FTP and TFTP better than HTTP server.
