Jason Pfeifer
osted By:
etychon
Posted Date:
Nov 20, 2008
Category:
Network Management
Version:
1.0
License:
Cisco-Style BSD
Summary:
Adds DHCP snooping exceptions when a fixed IP connects
Script Modified Date:
Apr 29, 2009
Cisco IOS Version tested:
12.2(44)SE2
Cisco Products Tested:
Cisco 3750
Environment Variables used:
none
Rating Count:
Average Rating:
File Size:
988 Bytes
Script Info URL:
Assuming some PCs are legitimately using a fixed IP address (ie:  servers), that a switch is having DHCP Snooping/IPSG active, and that  you do not want to manage the switch at the port level, this script will  disable DHCP Snooping for servers assuming they are not trying to steal  someone else's IP / MAC address.
Jozef Janitor
Hello, I wonder if anyone has ever downloaded this script - simply becuase I just did and the tar.gz file is empty (well, there is one single file: LICENCE.txt) 😉
Could you plase update the attached file. Thanks!
