SunilKhanna
    Abstract
    Embedded Event Manager (EEM) is a powerful tool  integrated with Cisco IOS Software for system management from within the  device itself. EEM offers the ability to monitor events and take  informational, corrective, or any desired action when the monitored  events occur or when a threshold is reached.
    This document helps in getting output of various troubleshooting commands when EIGRP neighbour flaps through EEM script.
    Prerequisite
    Knowledge of EIGRP and working of EEM script.
    Configuration
    Step 1:telnet the router.
    IMPORTANT: console access is not reliable and will miss characters when copy/pasting, telnet/ssh using TCP will take care that all characters are received.
    Step 2: Go in enable mode
    Step 3: EEM Configuration to register the script
    conf t
    event manager session cli username "{username}"
    event manager applet EIGRP_TROUBLESHOOT
    event syslog pattern "holding time expired"
    action 1.1 cli command "en"
    action 2.1 cli command "ping [IP Address of the EIGRP Neighbor] repeat 3 df"
    action 2.2 syslog priority debugging msg "cli: $_cli_result"
    action 3.1 cli command "debug eigrp packets hello"
    action 3.2 cli command "show ip EIGRP interface"
    action 3.3 syslog priority debugging msg "cli: $_cli_result"
    action 4.1 cli command "ping [IP Address of the EIGRP Neighbor] repeat 3 df"
    action 4.2 syslog priority debugging msg "cli: $_cli_result"
    action 5.1 cli command "debug eigrp packets hello"
    action 5.2 cli command "show ip EIGRP interface"
    action 5.3 syslog priority debugging msg "cli: $_cli_result"
    action 6.1 cli command "show ip EIGRP traffic"
    action 6.2 syslog priority debugging msg "cli: $_cli_result"
    action 7.0 cli command "un all"
    Step 4: show logging
    References
    netops3
    I am following this guide to troubleshoot an eigrp flap that we have. In my case the eigrp neighbor is in a GRE/IPSEC tunnel so instead of the eigrp neighbor interface I am pinging the ip address of the tunnel source interface of the neighbor to identify if my provider is dropping packets.
    Testing toward a non existing ip to simulate that the provider is dropping packet I get none of the output from $_cli_result so not sure how to proceed from there.
    Best Regards
    Jean Louis
