CscTsWebDocs
Community Member
Introduction:
This document describes how the eigrp summary route metrics is determined.
Core Issue:
There is a need to provide information on how the summary route metrics, which is created by the ip summary-address eigrp command, is determined and details of the summary-metric command implemented in association with the command.
Resolution:
  1. Configuration
  2. How the summary route metric is determined
  3. Using the summary-metric command
  4. All Devices Settings
1. Configuration
On R2, configure settings to summarize routes to 10.1.0.0/16 on the interface which connected to the R3
ip summary-address eigrp 1 10.1.0.0 255.255.0.0
(All setting examples are described at the end of this document)
(10.1.1.0/24)--1M--+
(10.1.2.0/24)-64K-[R1]-(10.12.1.0/24)-[R2]-(172.20.23/24)-[R3]
(10.1.3.0/24)-10M--+
(※ 15.1(4)M3 is used for all the output examples below)
For EIGRP, the smallest metric among the component routes (routes contained in the summary) will be employed as the summary route metric.
R2#show ip eigrp topology
EIGRP-IPv4 Topology Table for AS(1)/ID(172.20.1.2)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 172.20.1.0/24, 1 successors, FD is 281600
      via Connected, Ethernet1/0
P 10.12.1.0/24, 1 successors, FD is 281600
      via Connected, Ethernet0/0
P 10.1.3.0/24, 1 successors, FD is 307200
      via 10.12.1.1 (307200/281600), Ethernet0/0
P 10.1.0.0/16, 1 successors, FD is 307200
      via Summary (307200/0), Null0   <-- 307200, the smallest value among the component routes
P 10.1.2.0/24, 1 successors, FD is 40051200
      via 10.12.1.1 (40051200/40025600), Ethernet0/0
P 10.1.1.0/24, 1 successors, FD is 2611200
      via 10.12.1.1 (2611200/2585600), Ethernet0/0
R2#
If a component route is updated and the smallest metric is changed, the summary route metric is also updated.
If there are multiple metric values in a component route, care should be exercised during network design.
Example: If 10.1.3.0/24 with the smallest metric goes down
R2#debug ip eigrp summary
EIGRP-IPv4 Summary debugging is on
R2#
06:41:46.167: EIGRP-IPv4(1): summary_depend: dest 10.1.3.0/24 vec 0, metric 307200, add 0 auto 0
06:41:46.167: EIGRP-IPv4(1): summary_depend: revise summary 10.1.0.0/16
06:41:46.167: EIGRP-IPv4(1): summary_revise: result 2
06:41:46.167: EIGRP-IPv4(1): summary_enqueue: 10.1.0.0/16 vec(0) summary changed
06:41:46.167: EIGRP-IPv4(1): summary_depend: dest 10.1.3.0/24 vec 0, metric 0, add 0 auto 0
06:41:46.167: EIGRP-IPv4(1): summary_process: 3 components with static metric(0)
06:41:46.167: EIGRP-IPv4(1): summary_metric_calc: 10.1.0.0/16 with 3 components and metric 307200
06:41:46.167: EIGRP-IPv4(1): summary_metric overlapping: 10.1.2.0/24 metric 40051200
06:41:46.167: EIGRP-IPv4(1): summary_metric overlapping: 10.1.1.0/24 metric 2611200
06:41:46.167: EIGRP-IPv4(1): summary_metric_calc: 10.1.0.0/16, from 10.1.1.0/24, metric 2611200
06:41:46.167: EIGRP-IPv4(1): summary_process: 10.1.0.0/16 old(307200) new(2611200) processed(yes)
06:41:46.355: EIGRP-IPv4(1): summary_depend: dest 10.1.3.0/24 vec 0, metric 0, add 0 auto 0
06:41:46.355: EIGRP-IPv4(1): summary_depend: revise summary 10.1.0.0/16
06:41:46.355: EIGRP-IPv4(1): summary_revise: result 2
06:41:46.355: EIGRP-IPv4(1): summary_enqueue: 10.1.0.0/16 vec(0) summary changed
06:41:46.355: EIGRP-IPv4(1): summary_decr: 10.1.0.0/16 count(2)
06:41:46.355: EIGRP-IPv4(1): summary_process: 2 components with static metric(0)
06:41:46.355: EIGRP-IPv4(1): summary_metric_calc: 10.1.0.0/16 with 2 components and metric 2611200
06:41:46.355: EIGRP-IPv4(1): summary_metric overlapping: 10.1.2.0/24 metric 40051200
06:41:46.355: EIGRP-IPv4(1): summary_metric overlapping: 10.1.1.0/24 metric 2611200
06:41:46.355: EIGRP-IPv4(1): summary_metric_calc: 10.1.0.0/16, from 10.1.1.0/24, metric 2611200
06:41:46.355: EIGRP-IPv4(1): summary_process: 10.1.0.0/16 old(2611200) new(2611200) processed(yes)
R2#
      via Summary (2611200/0), Null0   <-- 2611200, the smallest value among the component routes
R2#
If there are many component routes to be summarized and the component routes are frequently updated, the metrics are also updated frequently, and thus a high CPU state may be caused depending on the configuration.
To deal with such a situation, the summary-metric command was implemented.
This command has been implemented in 12.2(33)SRE, 12.2(33)SXJ, 12.2(33)XNE/2.5.0, 15.0(1)M, 15.1(1)SG or later.
This command explicitly sets the metric for the summary regardless of the component route metric.
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#router eigrp 1
R2(config-router)#summary-metric 10.1.0.0/16 10000 200 255 0 1500
09:09:26.023: EIGRP-IPv4(1): summary metric cmd for 10.1.0.0/16
09:09:26.023: EIGRP-IPv4(1): summary metric dly(51200) bw(256000) r(255), l(0), mtu(1500) dist(5)
09:09:26.023: EIGRP-IPv4(1): summary_update - summary changed
09:09:26.023: EIGRP-IPv4(1): summary_enqueue: 10.1.0.0/16 vec(0) summary changed
09:09:26.039: EIGRP-IPv4(1): summary_process: 2 components with static metric(1)
09:09:26.039: EIGRP-IPv4(1): summary_process: 10.1.0.0/16 old(4294967295) new(307200) processed(yes)
R2(config-router)#end
R2#
      via Summary (307200/0), Null0   <-- 307200, regardless of the component route value
R2#
hostname R1
interface Ethernet0/0
ip address 10.12.1.1 255.255.255.0
interface Ethernet1/0
bandwidth 1000
ip address 10.1.1.1 255.255.255.0
interface Ethernet2/0
bandwidth 64
ip address 10.1.2.1 255.255.255.0
interface Ethernet3/0
bandwidth 10000
ip address 10.1.3.1 255.255.255.0
router eigrp 1
network 10.0.0.0
hostname R2
ip address 10.12.1.2 255.255.255.0
ip address 172.20.1.2 255.255.255.0
router eigrp 1
network 10.0.0.0
network 172.20.0.0
hostname R3
ip address 172.20.1.3 255.255.255.0
router eigrp 1
network 172.20.0.0
Related Information
Original Document: Cisco Support Community Japan DOC-26447
Author: Tsuyoshi Niitani
Posted on August 13, 2012
https://supportforums.cisco.com/docs/DOC-26447
