Aaron
If a wireless client is having problems roaming, it may be necessary to perform a "deep dive" data capture.  This will involve:
  • capturing information regarding the environment
  • reproducing the problem, while collecting:
    • packet capture from the client under test
    • wireless sniff from channels in use near the client
    • debugs from the APs involved
    • debugging from the wireless LAN controller(s) to which the AP(s) are joined
    • possibly also wired capture from the APs' and/or WLC's switchports
In more detail:
    • collect information on the client under test:
      • manufacturer, model
      • operating system
      • wireless adapter: manufacturer, model, firmware version
      • supplicant, supplicant version
      • if the client is running Windows: get the output of "netsh wlan show all"
    • collect information on the wireless infrastructure:
      • WLC model, software version
      • complete "show run-config" output from the WLC (to be used with WLC Config Analyzer)
      • a floormap or similar showing the location where the roaming test is performed, with AP names labeled (e.g. a floor map screenshot from WCS/NCS/PI)
      • site survey data from the location under test can be helpful
      • be sure that the client is NTP synced to true time
      • nonpromiscuous packet capture from the client's wireless adapter (e.g. Wireshark, tshark, tcpdump)
      • be sure to NTP sync all sniffers
      • with 2.4GHz, a 1/6/11 sniff is ideal
      • if you don't have enough sniffers for all channels in use, then find out which channels the client is using, or should be using, and monitor those channels
      • lock each sniffer to its channel - do not set the sniffers to scan
      • for multichannel sniffing, the following options can be used:
        • OmniPeek Enterprise with multiple Mediatek USB adapters (software from WildPackets)
        • OmniPeek Remote Assistant with multiple Mediatek USB adapters (software available from Cisco TAC)
        • Wireshark with AirPcap from Riverbed
        • multiple Mac OS X laptops, all NTP synced
        • (less preferred) multiple or Mac OS X laptopls, all NTP synced
        • (not recommended) Windows 7 laptops with Netmon 3.4
    • if there is possibility of significant non-802.11 interference in the environment (more likely in 2.4GHz than in 5GHz), then get a a spectrum capture near the location of concern during the the time of concern.  This could be done with Spectrum Expert with CleanAir APs (or with a Cognio Cardbus card), or with Chanalyzer from Metageek.
      • ideally, you will set up a syslog server that all APs can talk to, and configure the APs to send their debug output to that server.  This will enable all AP debugs to be nicely sequenced.
      • alternatively, you can run terminal sessions into all of the APs:
        • telnet or ssh into all APs in the roaming path
        • log each telnet/ssh session
        • set "terminal monitor" in each session
      • enter the following commands into each AP:
        • For IOS APs:
          debug capwap console cli   ! (hidden)
          config t
            no logging console
            logging buffered 1000000 debugging
            logging w.x.y.z   !(syslog server)
            logging trap debug
            line vty 0 4
              exec-timeout 240
            end
          debug dot11 dot11radio0 monitor address hhhh.hhhh.hhhh
          debug dot11 dot11radio0 monitor probe
          debug dot11 dot11radio0 trace print mgmt client
          (if using 5GHz, use "dot11radio1" in addition to / instead of "dot11radio0")
          debug capwap client mgmt
        • For 2800/3800 series APs:
          exec-timeout 720
          config ap client-trace address add <client_MAC-address>
          config ap client-trace filter all enable
          config ap client-trace output console-log enable
          config ap client-trace start
          debug client <client_MAC-address>
          terminal monitor
        • telnet/ssh into the WLC(s)
        • make sure that your WLC is NTP synced, with the minimum 3600 second interval
        • enter the following commands:
          config session timeout 160
          debug client hh:hh:hh:hh:hh:hh
          debug mobility handoff enable
            (only if multiple WLCs are in use)
    • start a continuous ping (e.g. a Windows ping -t) to the client under test, from a wired station in or near the wireless client's subnet
    • now reproduce the problem.
    • make a note of what time the problem happened, where the client under test was when the problem occured, what symptoms the client experienced (ping latency, ping drops), etc.
    • stop the packet capture on the client under test, the wireless sniffer(s), the debugs on the APs, the debugging on the WLCs, the wired sniffers (if in use)
    • from each AP, collect: "show controller dot11radio0" (or dot11radio1)
    • from the WLC, collect: "show msglog"
    • collect all of:
      • the note describing the event
      • the writeup describing the client device
      • the show run-config output from the WLC(s)
      • the map showing the area of interest
      • the nonpromiscuous capture from the client adapter
      • any other info from the client
      • the wireless sniffer captures (unfiltered, but do not include gigantic files that do not correspond to the time of interest)
      • the spectrum capture, if any
      • the AP log files
      • the WLC debugs/log files
      • the wired sniffer capture(s) if in use
    • zip all of these up together
  • Upload this data to your TAC case
Kamaljeet Singh
Community Member
Thank you Aaron for this great post.
Kamal
