TCC_2
Level 10
Level 10
Resolution
Issue these commands to enable the 10-Gigabit Ethernet and/or the Gigabit Ethernet Small Form-Factor Pluggable (SFP) uplink ports:
Switch#configure terminal
Switch(config)#hw-module uplink select {tengigabitethernet|gigabitethernet|all}
Note: On a Catalyst 4510R Series Switch, if you enable both the 10-Gigabit Ethernet and Gigabit Ethernet SFP uplink ports, you must re-boot the switch. On the Catalyst 4503, 4506, and 4507R Series Switches, this capability is automatically enabled.
Port type
1000 TX
victor.mor1s
     I have a Cisco 4507r+e, I am trying to get the sfp working. I am trying to follow the instructions above but there is no uplink option after hw-module. here are my options.
beacon Apply hw-module command to beacon LED
module Individual module in the system
module Specify a linecard slot for the hw-module command
slot Specify a linecard slot for the hw-module command
system Specify the system parameter
config:
SD-B1DISTF2-SW#sho int te3/1
TenGigabitEthernet3/1 is down, line protocol is down (notconnect)
Hardware is Ten Gigabit Ethernet Port, address is e02f.6da4.fb00 (bia e02f.6da4.fb00)
Description: SD-B1DIST-SW Te3/1 - L2/Trunk
MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is 10GBase-SR
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
description SD-B1DIST-SW Te3/1 - L2/Trunk
switchport trunk allowed vlan 1,5,10-12,20,60,120,901,999,1192
switchport trunk native vlan 999
switchport mode trunk
switchport nonegotiate
logging event trunk-status
storm-control broadcast level 10.00
spanning-tree portfast edge
end
