TCC_2
Level 10
Level 10
Resolution
In order to display the product inventory listing of all Cisco products installed in the networking device, use the show inventory command in user EXEC or privileged EXEC mode.
In some scenarios, it is seen that after you upgrade the Cisco IOS  on the Catalyst 6500 switch to Cisco IOS Software Release 12.2(18)SXF5 and later, the show inventory command does not display the serial number of the GBICS or it is blank as shown here:
NAME: "Gigabit Port Container 3/5", DESCR: "Gigabit Port Container"
PID: , VID:  , SN:
This reason this occurs is that GBICs and SFPs suppress the output because they are not yet Unique Device Identifier (UDI) compliant.
In such cases, issue the show inventory raw command, which retrieves information about all of the Cisco products installed in the networking device, even if the entities do not have a product ID (PID) value.
Refer to the How to Retrieve the Unique Device Identifier section of Unique Device Identifier Retrieval for more information.
bzyczek77
If you want to see what GBIC's and SFP's you are using you can also use the command on the Nexus switches.
sh interface transceiver
christionFly
The "sh interface transceiver" command displays optical light levels per SFP installed interface;
#sh int transceiver
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                               Optical       Optical
                Temperature Voltage Tx Power Rx Power
Port          (Celsius)       (Volts)   (dBm)      (dBm)
Gi0/15       44.6            3.28     -6.4       -9.3
Gi0/16       44.5            3.28     -5.5       -7.8
