TCC_2
Level 10
Level 10
Core Issue
Border Gateway Protocol (BGP) is an interdomain routing protocol used to exchange network reachability information with configured peers known as BGP neighbors. Interior BGP (IBGP) has certain behavior and follows certain rules to ensure that packet forwarding can take place correctly within the Autonomous System (AS) without any loops or black-holing. These are the most common problems with IBGP, mostly related to these rules and behavior:
  • BGP neighbors are not in established state.
  • A route is missing from the IP routing table due to an invalid route to next hop.
  • An IBGP route is not installed in the IP routing table and is not advertised to other neighbors, due to a BGP synchronization rule failure.
  • Routes learned from one IBGP neighbor are not advertised to another IBGP neighbor.
  • IBGP routes are not redistributed into an Interior Gateway Protocol (IGP).
Resolution
For more information, refer to these documents:
Type of Route Missing from Routing Table
All routes / All routes from specific neighbor
Valid Route to BGP Next Hop
Valid route to next hop does not exist
show ip bgp neighbors {neighbor  address}
State is active
