When you insert the TwinGig Converter in a Catalyst 4900M you get the following error message:
%C4K_TRANSCEIVERMAN-3-SEEPROMREADFAILED: Failed to read transceiver serial eeprom on port Te2/1, try reinserting
This error is probably because the device expects 10Gig transceivers to be connected to the device not 1Gig.
To use the TwinGig module you need to use the following command and change to Gig Ethernet:
"hw-module module <slot> port-group <group> select gigabitethernet"
Refer to Selecting X2/TwinGig Convertor Mode for more information.
Here is the sequence:
1. Insert the module and it will give the following error.
2. Add “hw-module module 2 port-group 1 select gigabitethernet” command
     *Apr 15 03:07:56: %C4K_GLMMAN-3-X2INTWINGIGCONVERTERHOLE: X2 inserted in port Te2/2, which is configured for a TwinGigConverter
    4w4d: Port Te2/1: TwinGig Converter inserted: vendor: CISCO SYSTEMS, p/n: 800-27645-01, s/n: FDO12140G92
So it will detect the TwinGig module.
3. Insert GLC-T in left side of TwinGig and it will detect the GLC-T as Gi2/9 port.
Also keep in mind on these TwinGig converters in the 4900M, the next 2 ports in that hardware group can only be gigabit, you cannot make the next port in the hardware group 10 gig once you have selected gigabit as the speed for that hardware group, so if ports 1 and 2 are gigabit then ports 3 and 4 can only be gigabit. This is a hardware limitation.
siamaher52
Hi Guys, I have the same issue with couple of Cisco 4900M switches. We just got them and tried to use the
TwinGig Converter on the 4 ports 10G module. The problem is that the switch sees the card and when we inserting yjr TwinGig Converter we get the error message and when we try to typew the command this command it does not work.
When we go to config T, the only thing we can type is
"hw-module module <slot> and if we do a ? the only thing is available is logging and power and we can't type
Port-Group or anything else. Does anybody know why? is this a hiden command or we have to something else?
Sia
