siskum
Hot Standby Router Protocol.
I belive this example solution helpful for who wants to established reliable internet network connection as well as Network redundent of home-office network.
HSRP Network RedundencyHSRP Network Redundency
ISP-Router 1 Configurations
ISP-R1#
ISP-R1#config t
ISP-R1(config)#interface GigabitEthernet0/0/0
ISP-R1(config-if)# ip address 10.35.20.2 255.255.255.248
ISP-R1(config-if)# ip nat inside
ISP-R1(config-if)# duplex auto
ISP-R1(config-if)# speed auto
ISP-R1(config)#interface GigabitEthernet0/0/1
ISP-R1(config-if)# ip address 10.35.40.2 255.255.255.248
ISP-R1(config-if)#exit
ISP-R1(config)#interface Serial0/1/0
ISP-R1(config-if)# ip address 172.10.100.1 255.255.255.248
ISP-R1(config-if)# ip nat outside
ISP-R1(config)#interface Serial0/1/1
ISP-R1(config-if)# ip address 172.10.200.1 255.255.255.248
ISP-R1(config-if)# clock rate 2000000
ISP-R1(config)#ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1
ISP-R1(config)#ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ISP-R1(config)#ip route 10.35.0.0 255.255.0.0 10.35.40.1
ISP-R1(config)#ip route 10.35.0.0 255.255.0.0 10.35.20.1
ISP-R1(config)#exit
ISP-R1#
ISP-R1#sh run
Building configuration...
Current configuration : 1068 bytes
version 16.6.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ISP-R1
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
ip nat outside
ip nat outside
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Home Office Router 3 Configurations
R3#
R3#config t
Enter configuration commands, one per line. End with CNTL/Z.
R3(config)#interface GigabitEthernet0/1
R3(config-if)# no ip address
R3(config-if)# ip nat inside
R3(config-if)# duplex auto
R3(config-if)# speed auto
R3(config-if)#exit
R3(config)#interface GigabitEthernet0/1.10
R3(config-subif)# encapsulation dot1Q 10
R3(config-subif)# ip address 10.35.10.1 255.255.255.0
R3(config-subif)# standby 10 ip 10.35.10.10
R3(config-subif)# standby 10 priority 140
R3(config-subif)# standby 10 preempt
R3(config-subif)#exit
R3(config)#interface GigabitEthernet0/1.30
R3(config-subif)# encapsulation dot1Q 30
R3(config-subif)# ip address 10.35.30.1 255.255.255.0
R3(config-subif)# standby 30 ip 10.35.30.30
R3(config-subif)# standby 30 priority 140
R3(config-subif)# standby 30 preempt
R3(config)#
R3(config)#ip dhcp pool Net10
R3(dhcp-config)# network 10.35.10.0 255.255.255.0
R3(dhcp-config)# default-router 10.35.10.1
R3(dhcp-config)#ip dhcp pool Net30
R3(dhcp-config)# network 10.35.30.0 255.255.255.0
R3(dhcp-config)# default-router 10.35.30.1
R3(dhcp-config)#exit
R3(config)#ip default-gateway 10.35.20.2
R3(config)#
R3(config)#ip route 10.35.30.0 255.255.255.0 GigabitEthernet0/1.30
R3(config)#ip route 10.35.10.0 255.255.255.0 GigabitEthernet0/1.10
R3(config)#ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
R3(config)#ip route 0.0.0.0 0.0.0.0 10.35.20.2
R3(config)#exit
R3#
R3>enable
R3#sh run
Current configuration : 1330 bytes
version 15.1
hostname R3
ip dhcp pool Net10
ip dhcp pool Net30
ip address 10.35.20.1 255.255.255.248
ip nat outside
duplex auto
speed auto
no ip address
ip nat inside
duplex auto
speed auto
standby 10 preempt
standby 30 preempt
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Home Office Router 4 Configurations
R4>enable
R4#config t
R4(config)#
R4(config)#interface GigabitEthernet0/0
R4(config-if)# ip address 10.35.40.1 255.255.255.248
R4(config-if)# ip nat outside
R4(config-if)# duplex auto
R4(config-if)# speed auto
R4(config-if)#exit
R4(config)#interface GigabitEthernet0/1
R4(config-if)# no ip address
R4(config-if)# ip nat inside
R4(config-if)#exit
R4(config)#interface GigabitEthernet0/1.10
R4(config-subif)# encapsulation dot1Q 10
R4(config-subif)# ip address 10.35.10.2 255.255.255.0
R4(config-subif)# standby 10 ip 10.35.10.10
R4(config-subif)# standby 10 priority 140
R4(config-subif)# standby 10 preempt
R4(config-subif)#exit
R4(config)#interface GigabitEthernet0/1.30
R4(config-subif)# encapsulation dot1Q 30
R4(config-subif)# ip address 10.35.30.2 255.255.255.0
R4(config-subif)# standby 30 ip 10.35.30.30
R4(config-subif)# standby 30 priority 140
R4(config-subif)# standby 30 preempt
R4(config)#
R4(config)#ip dhcp pool net10
R4(dhcp-config)# network 10.35.10.0 255.255.255.0
R4(dhcp-config)# default-router 10.35.10.2
R4(dhcp-config)#ip dhcp pool net30
R4(dhcp-config)# network 10.35.30.0 255.255.255.0
R4(dhcp-config)# default-router 10.35.30.2
R4(dhcp-config)#exit
R4(config)#ip default-gateway 10.35.40.1
R4(config)#
R4(config)#ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
R4(config)#ip route 10.35.10.0 255.255.255.0 GigabitEthernet0/1.10
R4(config)#ip route 10.35.30.0 255.255.255.0 GigabitEthernet0/1.30
R4(config)#ip route 0.0.0.0 0.0.0.0 10.35.40.2
R4(config)#exit
R4#
R4#sh run
Current configuration : 1442 bytes
version 15.1
hostname R4
ip dhcp pool net10
ip dhcp pool net30
ip nat outside
duplex auto
speed auto
no ip address
ip nat inside
duplex auto
speed auto
standby 10 preempt
standby 30 preempt
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Summery of Router Status
R3 - Router Status
R3>enable
R3#sh standby brief
P indicates configured to preempt.
Interface Grp Pri P State Active Standby Virtual IP
Gig 10 140 P Standby 10.35.10.2 local 10.35.10.10
Gig 30 140 P Standby 10.35.30.2 local 10.35.30.30
R3#
R4 - Router Status
R4>enable
R4#sh standby brief
Gig 10 140 P Active local 10.35.10.1 10.35.10.10
Gig 30 140 P Active local 10.35.30.1 10.35.30.30
R4#
