TCC_2
Level 10
Level 10
Core Issue
Hot Standby Router Protocol (HSRP) is used to build redundancy into IP networks. HSRP ensures that network downtime due to failure of devices is minimal and that the process of the backup device taking over the forwarding function is transparent to the end user.
However, HSRP cannot influence the path taken by the traffic entering the Autonomous System (AS). Border Gateway Protocol (BGP) can be used to influence the path taken by the incoming traffic, but it cannot provide first-hop failure redundancy for hosts on the network. HSRP and BGP together can influence the path for both incoming and outgoing traffic if connectivity to one Internet Service Provider (ISP) fails. Then the backup path to the other ISP used.
Resolution
To resolve this issue, perform these steps:
  1. Configure the router to be used for forwarding outbound traffic with a higher HSRP priority, making it the active HSRP router.
  2. Configure HSRP to track the state of the primary link to the ISP. If the link to the ISP fails, the HSRP priority of the router is reduced (by 10, by default), which results in the router's HSRP priority becoming less than that of the standby router. The HSRP standby router becomes the active router by virtue of its higher priority and starts forwarding traffic.
  3. To configure HSRP priority, issue the standby priority command in interface configuration mode.
  4. To configure HSRP to track an interface and change the HSRP priority based on the state of the interface, issue the standby track command.
  5. The router with the primary link can be configured to preempt. This is done to take over the role of the HSRP active router as soon as its link to the ISP is restored. To configure HSRP to preempt, issue the standby preempt command in interface configuration mode.
  6. To influence the path taken by the incoming traffic, prepend the local AS number to the updates sent out on the backup link more than once. This makes the updates sent out on the backup link have a longer AS-Path attribute, making them less preferable compared to updates sent over the primary link. The inbound traffic is now routed over the primary link.
  7. Create an Access Control List (ACL) to specify the updates for the AS-Path attribute that need modified. To define an ACL, issue the access-list command in global configuration mode.
  8. Create a new route map and configure it to match this ACL and modify the AS-Path attribute.
  9. To create a route map, issue the route-map command in global configuration mode.
  10. To match the destination network number specified in standard or extended ACL, issue the match ip address command in route-map configuration mode.
  11. To extend the length of the AS-Path attribute for these BGP routes, issue the set as-path command with the prepend keyword in route-map configuration mode.
For more information and configuration examples, refer to How to Use HSRP to Provide Redundancy in a Multihomed BGP Network.
eahmed007
I have configured EBGP between to Internet service provider and configured HSRP with IBGP for High-Availability for Local traffic. In this Network Topology, I have two Firewalls behind Two Routers where I configured EBPG Multi-homing.
ISP01                                 ISP02
     EBGP                             EBGP
Router01         IBGP     Router02
                    HSRP
Firewall01           Firewall02
I have one global network block 105.X.X.X/23. My intention is to use both ISP active for 105.X.X.X/24 and 105.X.Y.X/24 while configuring EBGP Multi-homing with HSRP protocol. That means 105.X.X.X/24 will use one ISP for incoming and outgoing traffic and 105.X.Y.X/24 will use other ISP and fail-over happens in case of one ISP goes down.
Can you tell me how I can configure to achieve this Active/Active High-Availability configuring BGP with HSRP protocol and keeping Firewall behind for LAN Network.
I am looking forward to your assistance.
With Regards
Erfan
siskum
HSRP Network RedundencyHSRP Network Redundency
HSRP-Reliable Internet Solution (Network Redundency)
ISP-Router 1 Configurations
ISP-R1#
ISP-R1#config t
ISP-R1(config)#interface GigabitEthernet0/0/0
ISP-R1(config-if)# ip address 10.35.20.2 255.255.255.248
ISP-R1(config-if)# ip nat inside
ISP-R1(config-if)# duplex auto
ISP-R1(config-if)# speed auto
ISP-R1(config)#interface GigabitEthernet0/0/1
ISP-R1(config-if)# ip address 10.35.40.2 255.255.255.248
ISP-R1(config-if)#exit
ISP-R1(config)#interface Serial0/1/0
ISP-R1(config-if)# ip address 172.10.100.1 255.255.255.248
ISP-R1(config-if)# ip nat outside
ISP-R1(config)#interface Serial0/1/1
ISP-R1(config-if)# ip address 172.10.200.1 255.255.255.248
ISP-R1(config-if)# clock rate 2000000
ISP-R1(config)#ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/1
ISP-R1(config)#ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
ISP-R1(config)#ip route 10.35.0.0 255.255.0.0 10.35.40.1
ISP-R1(config)#ip route 10.35.0.0 255.255.0.0 10.35.20.1
ISP-R1(config)#exit
ISP-R1#
ISP-R1#sh run
Building configuration...
Current configuration : 1068 bytes
version 16.6.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname ISP-R1
ip nat inside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
ip nat outside
ip nat outside
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Home Office Router 3 Configurations
R3#
R3#config t
Enter configuration commands, one per line. End with CNTL/Z.
R3(config)#interface GigabitEthernet0/1
R3(config-if)# no ip address
R3(config-if)# ip nat inside
R3(config-if)# duplex auto
R3(config-if)# speed auto
R3(config-if)#exit
R3(config)#interface GigabitEthernet0/1.10
R3(config-subif)# encapsulation dot1Q 10
R3(config-subif)# ip address 10.35.10.1 255.255.255.0
R3(config-subif)# standby 10 ip 10.35.10.10
R3(config-subif)# standby 10 priority 140
R3(config-subif)# standby 10 preempt
R3(config-subif)#exit
R3(config)#interface GigabitEthernet0/1.30
R3(config-subif)# encapsulation dot1Q 30
R3(config-subif)# ip address 10.35.30.1 255.255.255.0
R3(config-subif)# standby 30 ip 10.35.30.30
R3(config-subif)# standby 30 priority 140
R3(config-subif)# standby 30 preempt
R3(config)#
R3(config)#ip dhcp pool Net10
R3(dhcp-config)# network 10.35.10.0 255.255.255.0
R3(dhcp-config)# default-router 10.35.10.1
R3(dhcp-config)#ip dhcp pool Net30
R3(dhcp-config)# network 10.35.30.0 255.255.255.0
R3(dhcp-config)# default-router 10.35.30.1
R3(dhcp-config)#exit
R3(config)#ip default-gateway 10.35.20.2
R3(config)#
R3(config)#ip route 10.35.30.0 255.255.255.0 GigabitEthernet0/1.30
R3(config)#ip route 10.35.10.0 255.255.255.0 GigabitEthernet0/1.10
R3(config)#ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
R3(config)#ip route 0.0.0.0 0.0.0.0 10.35.20.2
R3(config)#exit
R3#
R3>enable
R3#sh run
Current configuration : 1330 bytes
version 15.1
hostname R3
ip dhcp pool Net10
ip dhcp pool Net30
ip address 10.35.20.1 255.255.255.248
ip nat outside
duplex auto
speed auto
no ip address
ip nat inside
duplex auto
speed auto
standby 10 preempt
standby 30 preempt
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Home Office Router 4 Configurations
R4>enable
R4#config t
R4(config)#
R4(config)#interface GigabitEthernet0/0
R4(config-if)# ip address 10.35.40.1 255.255.255.248
R4(config-if)# ip nat outside
R4(config-if)# duplex auto
R4(config-if)# speed auto
R4(config-if)#exit
R4(config)#interface GigabitEthernet0/1
R4(config-if)# no ip address
R4(config-if)# ip nat inside
R4(config-if)#exit
R4(config)#interface GigabitEthernet0/1.10
R4(config-subif)# encapsulation dot1Q 10
R4(config-subif)# ip address 10.35.10.2 255.255.255.0
R4(config-subif)# standby 10 ip 10.35.10.10
R4(config-subif)# standby 10 priority 140
R4(config-subif)# standby 10 preempt
R4(config-subif)#exit
R4(config)#interface GigabitEthernet0/1.30
R4(config-subif)# encapsulation dot1Q 30
R4(config-subif)# ip address 10.35.30.2 255.255.255.0
R4(config-subif)# standby 30 ip 10.35.30.30
R4(config-subif)# standby 30 priority 140
R4(config-subif)# standby 30 preempt
R4(config)#
R4(config)#ip dhcp pool net10
R4(dhcp-config)# network 10.35.10.0 255.255.255.0
R4(dhcp-config)# default-router 10.35.10.2
R4(dhcp-config)#ip dhcp pool net30
R4(dhcp-config)# network 10.35.30.0 255.255.255.0
R4(dhcp-config)# default-router 10.35.30.2
R4(dhcp-config)#exit
R4(config)#ip default-gateway 10.35.40.1
R4(config)#
R4(config)#ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
R4(config)#ip route 10.35.10.0 255.255.255.0 GigabitEthernet0/1.10
R4(config)#ip route 10.35.30.0 255.255.255.0 GigabitEthernet0/1.30
R4(config)#ip route 0.0.0.0 0.0.0.0 10.35.40.2
R4(config)#exit
R4#
R4#sh run
Current configuration : 1442 bytes
version 15.1
hostname R4
ip dhcp pool net10
ip dhcp pool net30
ip nat outside
duplex auto
speed auto
no ip address
ip nat inside
duplex auto
speed auto
standby 10 preempt
standby 30 preempt
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Please vote me as "Helpful" after sloving your problem. Thanks.
Summery of Router Status
R3 - Router Status
R3>enable
R3#sh standby brief
P indicates configured to preempt.
Interface Grp Pri P State Active Standby Virtual IP
Gig 10 140 P Standby 10.35.10.2 local 10.35.10.10
Gig 30 140 P Standby 10.35.30.2 local 10.35.30.30
R3#
R4 - Router Status
R4>enable
R4#sh standby brief
Gig 10 140 P Active local 10.35.10.1 10.35.10.10
Gig 30 140 P Active local 10.35.30.1 10.35.30.30
R4#
