Leo Laohoo
</body>
<P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" align=center mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;">I’m no electrical engineer, (the closest experience I have with electricity is the amount of electrocution I received when I was a child https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/64160/Drawing1.jpg" mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/64160/Drawing1.jpg" __jive_ID="64160" __jive_id="64160"></P> <P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;">
<BR style="PAGE-BREAK-BEFORE: always" clear=all mcestyle="page-break-before: always;"></STRONG></P> <P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;">What model of Cisco switch does TDR work on?
<P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;">Firstly, not all switch model support TDR. TDR feature first came out with the Catalyst 2960. So here is the list of which ones will work and will not:
<P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;"> </P> <TABLE style="WIDTH: 132.75pt; BORDER-COLLAPSE: collapse; MARGIN-LEFT: 144pt" class=mceItemTable border=0 cellSpacing=0 cellPadding=0 width=177 mcestyle="width: 132.75pt; border-collapse: collapse; margin-left: 144pt; padding: px;">
<TR style="HEIGHT: 15.75pt" mcestyle="height: 15.75pt;"> <TD style="BORDER-BOTTOM: windowtext 2.25pt double; BORDER-LEFT: windowtext 2.25pt double; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15.75pt; BORDER-TOP: windowtext 2.25pt double; BORDER-RIGHT: windowtext 2.25pt double; PADDING-TOP: 0cm" width=94 noWrap mcestyle="padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15.75pt; padding-top: 0cm; border: windowtext 2.25pt double;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Model</P></TD> <TD style="BORDER-BOTTOM: windowtext 2.25pt double; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15.75pt; BORDER-TOP: windowtext 2.25pt double; BORDER-RIGHT: windowtext 2.25pt double; PADDING-TOP: 0cm" vAlign=bottom width=83 noWrap mcestyle="border-bottom: windowtext 2.25pt double; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15.75pt; border-top: windowtext 2.25pt double; border-right: windowtext 2.25pt double; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">TDR Support</P></TD></TR> <TR style="HEIGHT: 17.25pt" mcestyle="height: 17.25pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 17.25pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 17.25pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">2960</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 17.25pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 17.25pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Yes1, 2
<TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">2960G</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Yes</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">2960S</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Yes</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">2918</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Unknown</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">2350</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Unknown</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">2360</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Unknown</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">2975</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Unknown</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">3560</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">No</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">3560G</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Yes</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">3560E/3560X</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Yes</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">3750</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">No</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">3750G</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Yes</P></TD></TR> <TR style="HEIGHT: 15pt" mcestyle="height: 15pt;"> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 70.75pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=94 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; padding-left: 5.4pt; width: 70.75pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">3750E/3750X</P></TD> <TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: medium none; PADDING-BOTTOM: 0cm; PADDING-LEFT: 5.4pt; WIDTH: 62pt; PADDING-RIGHT: 5.4pt; HEIGHT: 15pt; BORDER-TOP: medium none; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm" width=83 noWrap mcestyle="border-bottom: windowtext 1pt solid; border-left: medium none; padding-bottom: 0cm; padding-left: 5.4pt; width: 62pt; padding-right: 5.4pt; height: 15pt; border-top: medium none; border-right: windowtext 1pt solid; padding-top: 0cm;"> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 0pt" align=center mcestyle="text-align: center; line-height: normal; margin-bottom: 0pt;">Yes</P></TD></TR></TBODY></TABLE> <P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN: 0cm 0cm 1pt 36pt" mcestyle="text-align: justify; line-height: normal; margin: 0cm 0cm 1pt 36pt;">Note:
  1. •1. The 2960 will support TDR in both the FastEthernet and dual-personality GigiabitEthernet port, however, when used on a FastEthernet port, TDR will only test the first two pairs, namely Pairs A & B. For obvious reasons, Pairs C and D will not be tested when used on non-GigabitEthernet ports.
<P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN: 0cm 0cm 1pt 54pt" mcestyle="text-align: justify; line-height: normal; margin: 0cm 0cm 1pt 54pt;">
  1. •2. Except the WS-C2960-48PDL, when using the copper GigabitEthernet port of the Catalyst 2960, one must manually set the interface to copper using the command “media rj” before the test can be conducted.
<P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN: 0cm 0cm 1pt 54pt" mcestyle="text-align: justify; line-height: normal; margin: 0cm 0cm 1pt 54pt;"> </P> <P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;">The list does not include modules/blades for the Catalyst 4000/4500, 5000/5500, 6000/6500 although it is mentioned <A href="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/64163/Drawing2.jpg" mcesrc="https://supportforums.cisco.com/servlet/JiveServlet/downloadImage/64163/Drawing2.jpg" __jive_ID="64163" __jive_id="64163"></P> <P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;"> </P> <P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;">It means that the remote-end (Red) patch cable is missing.</P> <P style="TEXT-ALIGN: justify; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: justify; line-height: normal; margin-bottom: 1pt;"> </P> <P style="TEXT-ALIGN: center; LINE-HEIGHT: normal; MARGIN-BOTTOM: 1pt" mcestyle="text-align: center; line-height: normal; margin-bottom: 1pt;">-- END OF TRANSMISSION --</P>
