romenawer
Community Member
Could someone help me?
How to work a PVST vlan that is also belongs an MSTP instance, for example mst2? and How to work a MSTP instance that is also belong a PVST Vlan?
The root for the CIST is another root than the mst2.
Mohamed Sobair
Level 11
Level 11
The MSTP bridge simply simulte all PVST+ BPDUs by replicating CIST BPDUs on the Boundary link between the PVST+ bridge and the MSTP domain on the Trunk link between them. The MSTP bridge recieves all PVST+ BPDUs and process them using Internal Spanning-tree the (IST). The MSTP bridge view like another PVST+ domain to the PVST+.
The Cisco's Implementation recommends to have always the root bridge for all VLANs to be the CIST root bridge inside the region.
Mohamed
