SunilKhanna
    Introduction
    The document represents a configuration example of IPv6 Multiprotocol BGP peering between two routers using Link Local Address. Each router's active interface (here Serial 0/0) is configured with a unique link local address by command "ipv6 address {ipv6 address} link-local".
    Under BGP configuration mode, the remote router's link-local address is combined with keyword "update-source <interface type>". Using link-local addresses requires that the interface for the neighbor be identified by using the update-source command and that a route map be configured to set an IPv6 global next hop. Under the address-family mode, neighbour is activated and a route-map specifying the Next Hop is applied to the neighbour.
    Background
    In this document, two routers Austin and Dallas are forming EBGP peering over Serial 0/0 interface configured with IPv6 Link-Local addresses (Fe80:1::1 and FE80:2::1). The interfaces are also configured with Global Unicast Address (2012:1:1:1::x/64 in our topology). Austin is residing in AS 100 while the router Dallas in AS 200. Austin is advertising its Loopback 10 address (2012:10:10:10::10/128).
    Note: All configurations are tested on Cisco 3745 series router operating on C3745-ADVIPSERVICESK9-M, IOS Version 12.4(15)T14.
    Prerequisite
    1. IPv6 Addressing scheme
    2. Multiprotocol BGP
    Topology Diagram
    Configurations
    AustinDallas
    hostname Austin
    ip cef
    no ip domain lookup
    ipv6 unicast-routing
    interface Loopback10
    no ip address
    ipv6 address 2012:10:10:10::10/128
    interface Serial0/0
    no ip address
    ipv6 address FE80:1::1 link-local
    ipv6 address 2012:1:1:1::1/64
    ipv6 enable
    clock rate 2000000
    router bgp 100
    bgp router-id 1.1.1.1
    no bgp default ipv4-unicast
    bgp log-neighbor-changes
    neighbor FE80:2::1 remote-as 200
    neighbor FE80:2::1 update-source Serial0/0
    address-family ipv6
      neighbor FE80:2::1 activate
      neighbor FE80:2::1 route-map Next-Hop out
      network 2012:10:10:10::10/128
    exit-address-family
    route-map Next-Hop permit 10
    set ipv6 next-hop 2012:1:1:1::1
    end
    hostname Dallas
    ip cef
    no ip domain lookup
    interface Serial0/0
    no ip address
    ipv6 address FE80:2::1 link-local
    ipv6 address 2012:1:1:1::2/64
    ipv6 enable
    clock rate 2000000
    router bgp 200
    bgp router-id 2.2.2.2
    neighbor FE80:1::1 remote-as 100
    neighbor FE80:1::1 update-source Serial0/0
    address-family ipv6
      neighbor FE80:1::1 activate
      neighbor FE80:1::1 route-map Next-Hop out
    exit-address-family
    set ipv6 next-hop 2012:1:1:1::2
    end
    Verification
    1. show bgp ipv6 unicast summary
    2. show bgp ipv6 unicast
    References
    IPv6 FAQ
    Configuring an IPv6 Multiprotocol BGP Peer Using a Link-Local Address
    IP Version 6 (IPv6) - Cisco Systems
    Multiprotocol BGP for IPv6 Configuration Example
    mberend
    Community Member
    It seems to me that the result is identical to what you would get with peering to the global address.
    So then why would you ever do this? That is the benefit of this feature?
