08-08-2011 09:50 PM - edited 03-01-2019 04:42 PM
LICENSING on 2900/3500/3700
These are the 3 feature sets available on 3K platform of switches
(IP Services has all the feature sets that Advipservices had; advipservices is End Of Sale : http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/eol_c51_519629.html)
- 3560-E and 3750-E Series support the IP Base and IP Services feature sets
- 3560-X and 3750-X Series support the LAN Base, IP Base, and IP Services feature sets.
The software licenses are not affected by Cisco IOS software upgrades. A software license applies only to a specific feature set. A switch can have more than one software license, but you can enable only one license at a time.
- Software Activation is a feature that is preinstalled on the switch, which allows you to install the software license for a feature set.
- This Software Activation License is unique to a specific device. In other words, licenses are locked to the switch's unique device identifier(UDI).
- A unique device identifier is made up of two components: the product ID (PID) and serial number (SN). Serial number is an 11-digit number that uniquely identifies a device. The product ID identifies the type of device. This information can be found using the "show license udi" command on the switch CLI. So when you request for a license on the switch, the first thing that you need to have is this "UDI" of the device
Switch# show license udi
Device# PID SN UDI
*2 WS-C3750E-48PD-S CAT1033R1XU WS-C3750E-48PD-S:CAT1033R1XU
5 WS-C3750E-48PD-S CAT1033R1KF WS-C3750E-48PD-S:CAT1033R1KF
- A temporary software license is limited to a usage period (around 60 days). After the usage period expires, the switch continues to use the temporary software license until it is restarted. Before it restarts, warning messages state the switch is running the feature set without a valid license. After the switch restarts, the switch uses a valid software license based on the hierarchy (ipservices>ipbase>lanbase). If the switch does not have a valid license, it uses the IP base software license.
Switch#show license
Index 1 Feature: ipservices
Period left: 8 weeks 4 days <<<<<<< Limited usage period
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Priority: None
License Count: Non-Counted
Index 2 Feature: ipbase
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Here is the link that you could use to request for a temporary license:
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y
Note: On this link you should give the correct UDI of the switch (use "show license udi")
Catalyst 2960 and 2960S switches run one of these images:
1. The LAN base software image: which provides enterprise-class intelligent services such as ACLs and QoS features. On a Catalyst 2960-S switch, stacking is also supported.
2. The LAN Lite image: This image provides reduced functionality.
Catalyst 2960S image ships with universal image that includes cryptographic functionality. The software image on the switch is either the LAN base or LAN Lite image, depending on the switch model.
How to determine which image your switch is running on 2960?
i. Switches running the LAN Lite image do not support the FlexStack module. They do not have a FlexStack module slot on the rear of the switch.(more on FlexStack: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-578928.html)
ii. On the front of the switch, the label in the top right corner ends in –S if the switch model runs the LAN Lite image.
iii. Enter the show version privileged EXEC command. The line that shows the product ID also ends in either –L (if running the LAN base image) or –S (if running the LAN Lite image). For example, WS-C2960S-48PD-L is running LAN base; WS-C2960S-24TS-S is running LAN Lite image.
Catalyst 3750 and 3560 switches run feature-specific software releases and do not support software activation. The Catalyst 3560 switch is supported by either the IP base image or the IP services image. Hence the show license command doesn't work.
3560G#show license ^ % Invalid input detected at '^' marker. 3560G#show license ? % Unrecognized command
Catalyst 3750-E and 3560-E switches run the universal software image that has the Cisco IOS code for multiple feature sets (ipbase & ipservices). To enable a specific feature set, you must use the software activation feature to install the software license for that feature set. Catalyst 3750-E and 3560-E switches support either the noncryptographic or the cryptographic(k9 image) universal software image.
They support two software feature sets: IP Base and IP Services
Beginning with Cisco IOS Release 12.2(46)SE, the switches support these features:
- Temporary software licenses
- Rehosting a software license
- Cisco License Call Home
Note:
If the switch is running a software image earlier than Cisco IOS 12.2(46)SE, to run IP base feature - remove the IP services license from the switch, save the switch running configuration, and reload the switch. If the switch is running Cisco IOS Release 12.2(46)SE or later, enter thelicense boot level ipbase privileged EXEC command, save the switch running configuration, and reload the switch.
- If all the licenses are installed on the switch, the switch uses the highest license level, the IP services feature set.
Catalyst 3750-X/3560-X system is also loaded with a universal Cisco IOS Software image. Universal Cisco IOS Software images contain all Cisco IOS Software features. The level of Cisco IOS Software functionality available is determined by the combination of one (or more) licenses installed on the device. They support three software feature sets: LAN Base, IP Base, and IP Services.
Note:
For the Cisco Catalyst 3750-X/3560-X Series, in addition to universalk9 images, there are also images with the universalk9-npedesignation in the image name. The reason for this alternate image type is that some countries have import regulations that require that the device does not support any strong data-plane crypto functionality, such as IEEE 802.1AE, in any form. To satisfy the import requirements of those countries, this universal image does not support any strong payload encryption (that is, it is of the nonpayload encryption type).
Step1: Log in to the switch by using the console port, the Ethernet management port, or a Telnet session.
Step2: copy license file onto the flash: device from the tftp server.
Step3: Install the license on the switch with the following command in the privilege mode:
license install file-sys:file-sys//lic-location
Once the license gets installed a log message similar to this should be seen: "%IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Next reboot level = ipservices and License = ipservices"
Example:
Switch#license install flash:FDO1229V28R_20100704203238635.lic Installing licenses from "flash:FDO1229V28R_20100704203238635.lic" Extension licenses are being installed in the device with UDI "WS-C3560E-48PD-S:FDO1229V28R" for the following features: Feature Name: ipservices PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR LICENSE KEY PROVIDED FOR ANY CISCO PRODUCT FEATURE OR USING SUCH PRODUCT FEATURE CONSTITUTES YOUR FULL ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN. You hereby acknowledge and agree that the product feature license is terminable and that the product feature enabled by such license may be shut down or terminated by Cisco after expiration of the applicable term of the license (e.g., 30-day trial period). Cisco reserves the right to terminate or shut down any such product feature electronically or by any other means available. While alerts or such messages may be provided, it is your sole responsibility to monitor your terminable usage of any product feature enabled by the license and to ensure that your systems and networks are prepared for the shut down of the product feature. You acknowledge and agree that Cisco will not have any liability whatsoever for any damages, including, but not limited to, direct, indirect, special, or consequential damages related to any product feature being shutdown or terminated. By clicking the "accept" button or typing "yes" you are indicating you have read and agree to be bound by all the terms provided herein. ACCEPT? (yes/[no]): yes Installing...Feature:ipservices...Successful:Supported 1/1 licenses were successfully installed 0/1 licenses were existing licenses 0/1 licenses were failed to install Switch# 5w2d: %LICENSE-6-EULA_ACCEPTED: EULA for feature ipservices 1.0 has been accepted. UDI=WS-C3560E-48PD-S:FDO1229V28R; StoreIndex=-1:UNKNOWN License Store 5w2d: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3560e Next reboot level = ipservices and License = ipservices
Step4: The license is installed once you have accepted the EULA, but to enable the feature set after installing the license, you need to reload the device. Before reloading the device, the next license boot level of the switch has to be changed, use the following command to do so:
(In config mode) - license boot level license-level [switch switch-num]
If the show license all command displays the license as "Active, Not in Use, EULA not accepted," you can use the license boot level command to enable the license and accept the end-user license agreement (EULA).
Step5: Verify if the new license was installed:
- show version | in License|license
Switch#show ver | in license|License License Level: ipservices License Type: Evaluation Next reload license Level: ipservices
- show license detail (its very important to check if the EULA is accepted or not from the command).
Switch#show license det Index: 1 Feature: ipservices Version: 1.0 License Type: Evaluation License State: Active, In Use Evaluation total period: 8 weeks 4 days Evaluation period left: 8 weeks 3 days Expiry date: Apr 30 1993 00:00:25 License Priority: Low License Count: Non-Counted Store Index: 0 Store Name: Evaluation License Storage Index: 2 Feature: ipbase Version: 1.0 License Type: Permanent License State: Active, Not in Use License Priority: Medium License Count: Non-Counted Store Index: 0 Store Name: Primary License Storage
The above mentioned commands are sufficient for troubleshooting purposes, however there are other commands as well that might help under different circumstances:
- show license feature
Switch#show license feature
Feature name Enforcement Evaluation Clear Allowed Enabled
advipservices yes yes yes yes
ipservices yes yes yes no
ipbase no no yes no
(use this command to check the allowed features on the switch, as you can see this command gives you some more detail about what you could do with these features on the switch & each feature's its status)
- show license udi .
Switch#show license udi
Device# PID SN UDI
*0 WS-C3560E-48PD-S FDO1229V28R WS-C3560E-48PD-S:FDO1229V28R
(this command displays the Unique Device Identifier for each switch - which can be used during license generation. If you do not provide the correct UDI while requesting for a license (from TAC OR from the license portal), then you will not be able to install that license on the switch)
In software releases earlier than Cisco IOS Release 12.2(46)SE, you have the license clear license-level [switch switch-num] privileged EXEC command. Use the license-level parameter to specify the software license to remove. Use the switch switch-num parameter to specify the stack member. The switch switch-num option is supported only on Catalyst 3750-E switches.
In Cisco IOS Release 12.2(46)SE or later, if the software license is in use (active):
Switch#license clear ipservices Feature: ipservices 1 License Type: Evaluation License State: Active, Not in Use, EULA accepted Evaluation total period: 8 weeks 4 days Evaluation period left: 0 minute 0 second License Addition: Additive License Count: Non-Counted Comment: Store Index: 1 Store Name: Primary License Storage Are you sure you want to clear? (yes/[no]): yes Switch# 5w2d: %LICENSE-6-REMOVE: Feature ipservices 1.0 was removed from this device. UDI=WS-C3560E-48PD-S:FDO1229V28R; StoreIndex=1:Primary License Storage Backing up and saving software license information—Enter the license save {credential url | url} privileged EXEC command.
https://supportforums.cisco.com/docs/DOC-16501
https://supportforums.cisco.com/thread/2080956
Feel free to add any comments or post your questions, I shall try my best to answer those queries.
Ranganath Raju
Note On Stacking:
3750X needs ipbase or ipservices license to stack with other Non-lanbase 3750 swithces.
(http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-578933.html)
can we upgrade IP Service evaluation license on switch 3750x with LAN Base image.
WS-C3750X-24T-L - Part code.
Hi Mr Raju
Do you know how to temporary disable a license ?
We are working on a the Cisco 4451 that we recently purchased , regarding the perf licence we have a question, we would like to disable the perf. licence (temporarily.) Our concern is if we do will we be able to reload the licence as before?
Basically can we disable and load again several times ?
we have seen the following info in our router :
“To disable any technology package license, please issue the following configuration command, save configuration and reload the system. “
“Router(config)#license boot module technology-package disable”
Can you please advise ?
Many thanks !
Edsge
how to check license no. by which command
LAN Base:
IP Base:
IP Services:
what are these please give me one example for each...
Hi guys,
in a C3560X it's possible to make a license backup ?,
I will made a software upgrade and I would like to be sure of not lost the licence.
thanks
Good day, I´ll be very gratefully if some engineer tell me how I can buy IP services Licenses for Catalyst 3750-X.
The reason of this question is the local cisco partner told this switch is in EoS status and is not possible to get this licenses.
Thank you.
Thank you for the information, it has been insightful.
I do however, have a few things to clarify.
I plan on replacing the following switch models.
WS-C2960-24TT-L
WS-C3560X-24T-E
WS-C3750X-48P-L
WS-C4948E-F
From the above explanation, I now understand that with the
exception of 3560 switches, all other switches have licenses.
Question is;
1. Can I transfer licenses from these switches to the new switches after replacement?
If possible, how do I go about it?
2. Please whats the procedure for transferring licenses in a stacked switch environment?
3. Will I run into a license problem when replacing a stack module?
Thank you.
Link for the temporary license does not work (asking for user/password in http auth) ( https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y ) .
Is there any way to still get a temporary IP Services license for 3750-X ?
TP
