Kewal Agarwal
Load-interval command is used on interfaces to change the time period of packet-rate and throughput statistics. On the Nexus switches we can have upto three different counter for different time period.
You can configure load-interval on the interface regardless of its mode .i.e switch port or routed port
Nexus-9K--1# show interface eth1/3
Ethernet1/3 is up
admin state is up, Dedicated Interface
  Hardware: 100/1000/10000/25000 Ethernet, address: 003a.9c5e.86ca (bia 003a.9c5e.86ca)
  MTU 1500 bytes, BW 25000000 Kbit , DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  auto-duplex, auto-speed
  Beacon is turned off
  Auto-Negotiation is turned on  FEC mode is Auto
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned off
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
    admin fec state is auto, oper fec state is auto
  Last link flapped never
  0 interface resets
  Load-Interval #1: 30 seconds
    30 seconds input rate 0 bits/sec, 0 packets/sec
    30 seconds output rate 0 bits/sec, 0 packets/sec
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  Load-Interval #2: 5 minute (300 seconds)
    300 seconds input rate 0 bits/sec, 0 packets/sec
    300 seconds output rate 0 bits/sec, 0 packets/sec
  RX
    4 unicast packets  0 multicast packets  0 broadcast packets
    4 input packets  2452 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    4 output packets  2452 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
Nexus-9K--1(config)# interface eth1/3
Nexus-9K--1(config-if)# load-interval ?
  <5-300>  Load interval delay in seconds
  counter  Specify counter for this load interval
Nexus-9K--1(config-if)# load-interval counter ?
  <1-3>  Specify counter for this load interval
Nexus-9K--1(config-if)# load-interval counter 3 ?
Nexus-9K--1(config-if)# load-interval counter 3 60
Nexus-9K--1(config-if)# end
Nexus-9K--1# show int eth1/3
Ethernet1/3 is up
  Port mode is access
  EtherType is 0x8100
  0 interface resets
  Load-Interval #3: 1 minute (60 seconds)
    60 seconds input rate 0 bits/sec, 0 packets/sec
    60 seconds output rate 0 bits/sec, 0 packets/sec
  RX
    0 Rx pause
  TX
    0 jumbo packets
    0 Tx pause
However, when the port is configured as routed port make sure that it not configured with p2p medium. You can only configure load-interval when the port is in default medium of broadcast.
Nexus-9K--1# show run int eth1/1
!Command: show running-config interface Ethernet1/1
!Running configuration last done at: Mon Sep 12 10:36:57 2022
!Time: Mon Sep 12 10:38:56 2022
version 9.3(8) Bios:version 05.44
  description UPLINK TO SPINE-1
  mtu 9216
  logging event port link-status
  medium p2p
  no ip redirects
  ip address 10.1.1.1/31
  ip ospf network point-to-point
  ip router ospf 65001 area 0.0.0.0
  ip ospf bfd
  ip pim bfd-instance
  ip pim sparse-mode
  ip arp timeout 900
  no shutdown
Nexus-9K--1# conf t
Enter configuration commands, one per line. End with CNTL/Z.
Nexus-9K--1(config)# int eth1/1
Nexus-9K--1(config-if)# load ?
*** No matching command found in current mode, matching in (exec) mode ***
  bootflash:  Enter image URI
  volatile:   Enter image URI
Nexus-9K--1(config-if)# medi
media-type   medium
Nexus-9K--1(config-if)# medium broadcast
Nexus-9K--1(config-if)# load-interval counter 1 ?
