ZhengWeiWei83103
Community Member
HI
i have 3 4510R switchs,now in two switchs i make a etherchannel,if i do more etherchannels to connect third 4510R,does it works?
the topo like:
4510R------EC-----4510R
       -EC              -EC
           - 4510R-
the third 4510R use two EC to connect other two 4510Rs,does the STP can work to prevent loop?
thanks
andrew.prince
Level 11
Level 11
Yes it will work.
ZhengWeiWei83103
Community Member
thanks
so,one EC port will be block,as the same of physical port?
andrew.prince
Level 11
Level 11
Yes - if you have configured the EtherChannel as a layer 2 port, then it acts as any switchport.  If you have configured it as a layer 3 routed port - it will act like any layer 3 interface.
