ataranen
We got FAB-2 (N7K-C7010-FAB-2) with quite an old EPLD .004, and decided to upgrade to a newer version to ensure it operates properly in SUP2 and F3 environment. However the upgrade procedure keeps failing with the messages below. Should I assume the hardware is faulty ?
switch# install xbar-module 1 epld bootflash:n7000-s1-epld.6.0.1.img
Copy complete, now saving to disk (please wait)...
Retrieving EPLD versions... Please wait.
Images will be upgraded according to following table:
Module  Type           EPLD      Running-Version   New-Version  Upg-Required
     1  Xbar  Power Manager              0.004       0.006          Yes
Xbar Module 1 will be powered down.
2008 Dec 28 21:16:06 switch %$ VDC-1 %$ %PLATFORM-2-XBAR_DETECT: Xbar 1 detected (Serial number JAF1522AARL)
2 EPLD upgrade failed. Exiting..
 Failure reason: Programming failed while upgrading the FPGA. (Error Number : 1)
     6   SUP  Power Manager              3.009       3.009           No
     6   SUP  IO                         3.028       3.028           No
     6   SUP  Inband                     1.008       1.008           No
     6   SUP  Local Bus CPLD             3.000       3.000           No
     6   SUP  CMP CPLD                   6.000       6.000           No
     1   FAN  Fan Controller (1)         0.007       0.007           No
     1   FAN  Fan Controller (2)         0.007       0.007           No
     2   FAN  Fan Controller (1)         0.007       0.007           No
     2   FAN  Fan Controller (2)         0.007       0.007           No
     3   FAN  Fan Controller (1)         0.007       0.007           No
     3   FAN  Fan Controller (2)         0.007       0.007           No
     4   FAN  Fan Controller (1)         0.007       0.007           No
     4   FAN  Fan Controller (2)         0.007       0.007           No
The above modules require upgrade.
Starting Xbar Module 1 EPLD Upgrade
2008 Dec 28 21:18:32 switch %$ VDC-1 %$ %PLATFORM-2-XBAR_DETECT: Xbar 1 detected (Serial number JAF1522AARL)
EPLD Upgrade Completed.
Module    Type  Upgrade-Result
     1    Xbar          Failed
nazick02
As a Beginner, I don't think the hardware is faulty. Can you try upgrading the hardware and let me know if the issue still persists?
helpcenterus
I'm sorry, but I'd like to know if this problem has been solved or not? If so, let me know how!
