Meddane
Basic configuration of all routers:
R1:
ipv uni
interface FastEthernet0/0
 ip address 192.168.123.1 255.255.255.0
 ipv6 address 123::1/64
 ipv6 ospf 1 area 123
 no shut
interface FastEthernet0/1
 ip address 12.12.12.1 255.255.255.0
 ipv6 address 12::1/64
 ipv6 ospf 1 area 0
 no shut
interface FastEthernet1/0
 ip address 192.168.13.1 255.255.255.0
 ipv6 address 13::1/64
 ipv6 ospf 1 area 0
 no shut
router ospf 1
 router-id 1.1.1.1
 area 123 nssa
 network 12.12.12.0 0.0.0.255 area 0
 network 192.168.13.0 0.0.0.255 area 0
 network 192.168.123.0 0.0.0.255 area 123
ipv6 router ospf 1
 router-id 11.11.11.11
 area 123 nssa
R2:
ipv uni
 ip address 192.168.123.2 255.255.255.0
 ipv6 address 123::2/64
 no shut
 ip address 12.12.12.2 255.255.255.0
 ipv6 address 12::2/64
 ipv6 ospf 1 area 0
 no shut
router ospf 1
 router-id 2.2.2.2
 area 123 nssa
ipv6 router ospf 1
 router-id 22.22.22.22
 area 123 nssa
R3:
ipv uni
interface Loopback0
 ipv6 address 3::3/64
interface Loopback1
 ip address 3.3.3.3 255.255.255.0
 ip address 192.168.123.3 255.255.255.0
 ipv6 address 123::3/64
 no shut
 ip address 192.168.13.3 255.255.255.0
 ipv6 address 13::3/64
 ipv6 ospf 1 area 0
 no shut
router ospf 1
 router-id 3.3.3.3
 area 123 nssa
 redistribute connected subnets route-map CONNECTED-IPV4
ipv6 router ospf 1
 router-id 33.33.33.33
 area 123 nssa
 redistribute connected route-map CONNECTED-IPV6
route-map CONNECTED-IPV4 permit 10
 match interface Loopback1
route-map CONNECTED-IPV6 permit 10
 match interface Loopback0
AREA 123 is configured as NSSA
R1 and R2 should inject two LSAs Type 7 Default-Route in NSSA with the following commands in OSPFv2 and OSPFv3:
R1(config-rtr)#area 123 nssa default-information-originate
R2(config-router)#area 123 nssa default-information-originate
R3 advertises its external prefixes 3::3/64 and 3.3.3.3/24 in OSPFv3 OSPFv2 respectively.
Case with OSPFv3:
R3 receives two LSAs Type 7 default route :: from R2(22.22.22.22) and R1 (11.11.11.11) without P Bit (not set) as shown by the line "Options:None" ,also R3 generates an LSA Type 7 for the external prefix 3::/64 and inject it in NSSA but with P-Bit set to 1 in order to tell the ABRs R1 and R2 to translate that an LSA Type 7 into an LSA Type 5 as shown by the line " Options: P " meaning that the P-Bit is set to 1 :
R3#show ipv ospf data nssa-external
            OSPFv3 Router with ID (33.33.33.33) (Process ID 1)
                Type-7 AS External Link States (Area 123)
  Routing Bit Set on this LSA
  LS age: 1596
  LS Type: AS External Link
  Link State ID: 0
  Advertising Router: 11.11.11.11
  LS Seq Number: 80000001
  Checksum: 0x36D3
  Length: 28
  Prefix Address: ::
  Prefix Length: 0, Options: None
  Metric Type: 2 (Larger than any link state path)
  Metric: 1
  LS age: 1618
  Link State ID: 0
  Advertising Router: 22.22.22.22
  Checksum: 0xEAF2
  Length: 28
  Prefix Address: ::
  Metric: 1
  LS age: 1638
  Link State ID: 1
  Advertising Router: 33.33.33.33
  Checksum: 0x3E0C
  Length: 36
  Prefix Address: 3::
  Prefix Length: 64, Options: P
  Metric: 20
Notice R3 installs two Default-route (load-balancing) :
R3#show ipv route ::
ON2  ::/0 [110/1]
     via FE80::C201:1DFF:FE04:0, FastEthernet0/0
     via FE80::C200:1DFF:FE04:0, FastEthernet0/0
Case with OSPFv2:
R3 receives two LSAs Type 7 default route 0.0.0.0 from R2(2.2.2.2) and R1 (1.1.1.1) without P Bit (not set) as shown by the line "No Type 7/5 translation" in the option field ,also R3 generates an LSA Type 7 for the external subnet 3.3.3.0/24 and inject it in NSSA but with P-Bit set to 1 in order to tell the ABRs R1 and R2 to translate that LSA Type 7 into an LSA Type 5 as shown by the line " Type 7/5 translation " in the option field meaning that the P-Bit is set to 1:
R3#show ip ospf data nssa-external
            OSPF Router with ID (3.3.3.3) (Process ID 1)
  LS age: 1787
  Options: (No TOS-capability, No Type 7/5 translation, DC)
  Link State ID: 0.0.0.0 (External Network Number )
  Advertising Router: 1.1.1.1
  Checksum: 0xEEBE
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
        Forward Address: 0.0.0.0
        External Route Tag: 0
  LS age: 1808
  Advertising Router: 2.2.2.2
  Checksum: 0xD0D8
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
  LS age: 1825
  Options: (No TOS-capability, Type 7/5 translation, DC)
  Link State ID: 3.3.3.0 (External Network Number )
  Advertising Router: 3.3.3.3
  Checksum: 0x2C6D
  Length: 36
  Network Mask: /24
        TOS: 0
        Metric: 20
        Forward Address: 192.168.123.3
R3#show ip route | s 0.0.0.0
Gateway of last resort is 192.168.123.2 to network 0.0.0.0
O*N2 0.0.0.0/0 [110/1] via 192.168.123.2, 00:09:36, FastEthernet0/0
               [110/1] via 192.168.123.1, 00:09:36, FastEthernet0/0
Now we will add a link between R1 and R3 (fa1/0--fa1/0)and configure this link in area 0 with both IPv6 address and an IPv4 address,as a result R3 will become also an ABR:
R1(config-router)#int fa1/0
R1(config-if)#ipv6 address 13::1/64
R1(config-if)#ip address 192.168.13.1 255.255.255.0
R1(config-if)#ipv ospf 1 area 0
R1(config-if)#router ospf 1
R1(config-router)#network 192.168.13.0 0.0.0.255 area 0
R3(config)#int fa1/0
R3(config-if)#ipv6 address 13::3/64
R3(config-if)#ip address 192.168.13.3 255.255.255.0
R3(config-if)#ipv ospf 1 area 0
R3(config-if)#exi
R3(config)#router ospf 1
R3(config-router)#network 192.168.13.0 0.0.0.255 area 0
Case with OSPFv3:
% Route not found
Case with OSPFv2:
R3#show ip route 0.0.0.0
% Network not in table
Notice that R3 loses its default route, in OSPFv3 and OSPFv2.
Notice that R3 still receives the LSA Type 7 default route in OSPFv3 and OSPFv2 as shown by the show ipv6 ospf data nssa-external and the show ip ospf data nssa-external commands respectively:
R3#show ipv6 ospf data nssa-external
  LS age: 1325
  Link State ID: 0
  LS Seq Number: 80000002
  Checksum: 0x34D4
  Length: 28
  Prefix Address: ::
  Metric: 1
  LS age: 1308
  Link State ID: 0
  Checksum: 0xE8F3
  Length: 28
  Prefix Address: ::
  Metric: 1
  ...Output omitted for brevity
  LS age: 1326
  Checksum: 0xECBF
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
  LS age: 1417
  Checksum: 0xCED9
  Length: 36
  Network Mask: /0
        TOS: 0
        Metric: 1
R3 installs the two LSAs Type 7 default route advertised by R1 and R2 in the OSPF database, but it does not install the Default routes into the routing table ,because When an ABR receives an LSA Type 7 default route from another ABR ,it looks the P bit and find that it is not set ,then it does not install the default route because the loop prevention mechanism.Remember that the P-bit is only used in the LSA Type 7 to tell the ABRs to translate this LSA into an LSA Type 5,but this P bit is also used as a routing loop prevention mechanism. In this case since R3 is an ABR after adding the link Fa1/0--fa1/0(R1--R3), it does not accept the LSA Type 7 without P-bit, in order to avoid routing loops.
The RFC 1587 Section 3.4 "Originating Type-7 LSAs
A type-7 default route (network 0.0.0.0) may be originated into the
   NSSA by an NSSA area border router or by an NSSA AS boundary router
   which is internal to the NSSA.  The type-7 default route originated
   by the NSSA area border router must have the P-bit reset so that the
   default route originated by the NSSA area border router will not find
   its way out of the NSSA into the rest of the AS system via another
   NSSA area border router.  The type-7 default route originated by an
   NSSA AS boundary router which is not an NSSA area border router may
   have the P-bit set.  Type-7 routes which are originated by the NSSA
   area border router will not get added to other NSSA area border
   router's routing table.
RFC 3101 The OSPF Not-So-Stubby Area (NSSA) Option
Appendix F: A Type-7 default route with the P-bit clear will not be
         installed on an NSSA border router.  This protects the default
         routing of other OSPF Areas.  (See Appendix E.)
