parkjaehyun
Community Member
Does anyone know what this means?
They are os bugs? Or correspondence Port being defective and the stamp being larger than actual appearance.
Oct 28 13:41:52: %ILPOWER-7-DETECT: Interface Fa0/20: Power Device detected: IEEE PD
Oct 28 13:41:52: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/20: Power Controller reports power Imax error detected
Oct 28 13:42:01: %ILPOWER-7-DETECT: Interface Fa0/20: Power Device detected: IEEE PD
Oct 28 13:42:01: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/20: Power Controller reports power Imax error detected
Oct 28 13:42:10: %ILPOWER-7-DETECT: Interface Fa0/20: Power Device detected: IEEE PD
Oct 28 13:42:11: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/20: Power Controller reports power Imax error detected
Oct 28 13:42:20: %ILPOWER-7-DETECT: Interface Fa0/20: Power Device detected: IEEE PD
Oct 28 13:42:20: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/20: Power Controller reports power Imax error detected
Oct 28 13:42:30: %ILPOWER-7-DETECT: Interface Fa0/20: Power Device detected: IEEE PD
Oct 28 13:42:30: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/20: Power Controller reports power Imax error detected
Oct 28 13:42:40: %ILPOWER-7-DETECT: Interface Fa0/20: Power Device detected: IEEE PD
Oct 28 13:42:40: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/20: Power Controller reports power Imax error detected
show power inline
Available:370.0(w)  Used:199.2(w)  Remaining:170.8(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Fa0/1     auto   on         8.3     Ieee PD             3     15.4
Fa0/2     auto   on         8.3     Ieee PD             2     15.4
Fa0/3     auto   on         8.3     Ieee PD             3     15.4
Fa0/4     auto   on         8.3     Ieee PD             2     15.4
Fa0/5     auto   on         8.3     Ieee PD             3     15.4
Fa0/6     auto   on         8.3     Ieee PD             2     15.4
Fa0/7     auto   on         8.3     Ieee PD             3     15.4
Fa0/8     auto   on         8.3     Ieee PD             3     15.4
Fa0/9     auto   on         8.3     Ieee PD             2     15.4
Fa0/10    auto   on         8.3     Ieee PD             3     15.4
Fa0/11    auto   on         8.3     Ieee PD             3     15.4
Fa0/12    auto   on         8.3     Ieee PD             3     15.4
Fa0/13    auto   on         8.3     Ieee PD             3     15.4
Fa0/14    auto   on         8.3     Ieee PD             3     15.4
Fa0/15    auto   on         8.3     Ieee PD             3     15.4
Fa0/16    auto   on         8.3     Ieee PD             3     15.4
Fa0/17    auto   on         8.3     Ieee PD             3     15.4
Fa0/18    auto   on         8.3     Ieee PD             3     15.4
Fa0/19    auto   on         8.3     Ieee PD             3     15.4
Fa0/20    auto   on         8.3     Ieee PD             2     15.4
Fa0/21    auto   off        0.0     n/a                 n/a   15.4
Fa0/22    auto   off        0.0     n/a                 n/a   15.4
Fa0/23    auto   on         8.3     Ieee PD             3     15.4
Fa0/24    auto   off        0.0     n/a                 n/a   15.4
Fa0/25    auto   on         8.3     Ieee PD             3     15.4
Fa0/26    auto   off        0.0     n/a                 n/a   15.4
Fa0/27    auto   on         8.3     Ieee PD             3     15.4
Fa0/28    auto   on         8.3     Ieee PD             3     15.4
Fa0/29    auto   off        0.0     n/a                 n/a   15.4
Fa0/30    auto   off        0.0     n/a                 n/a   15.4
Fa0/31    auto   off        0.0     n/a                 n/a   15.4
Fa0/32    auto   off        0.0     n/a                 n/a   15.4
Fa0/33    auto   off        0.0     n/a                 n/a   15.4
Fa0/34    auto   off        0.0     n/a                 n/a   15.4
Fa0/35    auto   off        0.0     n/a                 n/a   15.4
Fa0/36    auto   off        0.0     n/a                 n/a   15.4
Fa0/37    auto   off        0.0     n/a                 n/a   15.4
Fa0/38    auto   off        0.0     n/a                 n/a   15.4
Fa0/39    auto   off        0.0     n/a                 n/a   15.4
Fa0/40    auto   off        0.0     n/a                 n/a   15.4
Fa0/41    auto   off        0.0     n/a                 n/a   15.4
Fa0/42    auto   off        0.0     n/a                 n/a   15.4
Fa0/43    auto   off        0.0     n/a                 n/a   15.4
Fa0/44    auto   off        0.0     n/a                 n/a   15.4
Fa0/45    auto   off        0.0     n/a                 n/a   15.4
Fa0/46    auto   off        0.0     n/a                 n/a   15.4
Fa0/47    auto   off        0.0     n/a                 n/a   15.4
Fa0/48    auto   off        0.0     n/a                 n/a   15.4
show ver
cisco WS-C3560-48PS (PowerPC405) processor (revision P0) with 122880K/8184K bytes of memory.
Processor board ID FDO1216Z2W0
Last reset from power-on
3 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:21:1C:F6:72:00
Motherboard assembly number     : 73-9676-13
Power supply part number        : 341-0029-05
Motherboard serial number       : FDO12160GPA
Power supply serial number      : LIT1212056A
Model revision number           : P0
Motherboard revision number     : A0
Model number                    : WS-C3560-48PS-S
System serial number            : FDO1216Z2W0
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : FDO12150VK8
Top Assembly Part Number        : 800-25859-04
Top Assembly Revision Number    : A0
Version ID                      : V05
CLEI Code Number                : COMU210ARA
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   52     WS-C3560-48PS      12.2(35)SE5             C3560-IPBASE-M
Configuration register is 0xF
