Aaron
Release Notes for Cisco Wireless LAN Controllers (WLC) and Lightweight Access Points (AP) for Release 7.0.116.0
New Features:-
wIPS ELM
Voice Diagnostics
Rogue Containment and RLDP Enhancements
Calibration Enhancements
Hybrid REAP: Local Authentication
Hybrid REAP Fault Tolerance
Hybrid REAP OKC Feature
CDP Over Air
Preferred Call Support
DHCP Option 60
PCI Compliance for Neighbor Packets
RF Grouping
Chile Regulatory Enhancements
Russia Regulatory Enhancements
Licensing Changes for 5500 Series Controllers
Non-Cisco WGB Support
Cisco Identity Services Engine Support
PSB Enhancements
DHCP Option 82 Support for Ethernet MAC ID
VLAN Select and Related Features
Dynamic Anchoring Support for Static IP Clients
Fast Controller Failover
Webauth Proxy
Client Limits Per WLAN
FIPS Support
Resolved Bugs
Resolved Caveats
ID Number
Caveat Title
CSCsj33229
Unable to ping APs directly connected to a 2106 controller.
CSCtg73740
AP should default AAA ports to 1812/1813 not 1645/1646.
CSCtg66192
5508 WLC - solid amber alarm light.
CSCtb72660
NEC SIP CAC: Load-based CAC is not working with non-WMM clients.
CSCtl44908
DCA channel lists changes when WLC is upgraded to 6.0/7.0 from 4.2.
CSCtl95978
WLC will not respond to SNMP if its source address is part of a dynamic interface.
CSCtg51544
MSFT: Multiple SSH sessions can cause arrow key failure and password to appear.
CSCtf78029
SNMP traps for 1231 AP also sent for Interface:1(unknown type).
CSCtd21754
Huck Jr "b" radio status moves from disabled to enabled after reboot.
CSCtg44663
WGB: multiple parents created during roaming traffic disrupted.
CSCtg67029
The command show client tsm does not display full output.
CSCtg66175
RLDP does not work on CT5500 or WLC2100 + HREAP AP.
CSCtf38802
SIP calls on roaming with CAC failure connects back without B/W reserved.
CSCtg65856
Counters not cleared during intra-controller roaming of SIP calls.
CSCtg74333
Addition of VOICE_CALL_FAILURE_5 Enum to QOS MIB.
CSCtg70271
WEBAUTH_REQD (8) Reached ERROR: occurred from the line 4055 in client debug.
CSCsy18685
Default-group for AP-groups does not contain all SSIDs.
CSCtg84677
AP is deauthenticated with a reason: power capability is unacceptable.
CSCtf27464
Management interface does not use HSRP MAC address when replying.
CSCtf51294
Cannot clear webauth bundle from controller.
CSCtg92171
WLC stops responding to network.
CSCtf62737
Controller URL sanitation issue.
CSCtf90579
With TACACS/RADIUS authentication, lobby admin was unable to edit the guest user role.
CSCtg09589
Duplex mismatch occurs when the 1140 the access point is directly connected to a Cisco 2100 Series Controller.
CSCtg21950
WGB intracontroller roaming must update its clients without an IAPP frame.
CSCtg03203
The access points 1142/1252 recognize 802.11n HT enabled clients as legacy ones.
CSCtg23491
The controller does not process flooded unicast traffic properly.
CSCtg23618
WiSM goes unreachable outside of the Catalyst 6500 Series Switch.
CSCtg30694
Controller webauth client never has to reauthenticate after session timeout.
CSCtg51702
Degraded voice performance occurs on HREAP local switching with TKIP + CCKM.
CSCtg57607
WGB fails to send IAPP updates after roaming.
CSCtg95111
The access point which is not correctly primed, keeps reconnecting with the master.
CSCtk53680
WiSM not able to FTP core dump when running low on memory.
CSCtg55102
HREAP: AssocFailPayload causes payload error in the controller.
CSCsg48089
Controller needs password recovery mechanism without losing configuration.
CSCsi27596
Controller lacks support for controlling the group key rotation interval.
CSCso22875
Access points get disconnected during code upgrade.
CSCso60597
AP 1250 fails to configure 40-MHz wide channel for sniffer mode.
CSCsq65895
DHCP proxy option does not validate if DHCP is required on WLAN.
CSCsr10874
Additional client statistics required for autonomous access points.
CSCsw80627
Controller fails to respond on task emWeb in 5.1.151.0.
CSCsx14840
LAG: Management interface change between port BIA and LAG port address.
CSCsx50408
LWAP DOS Attack trap message does not record the source MAC address.
CSCsy28323
Need to improve MFP scalability.
CSCsy30722
Next hop address stored in CAPWAP does not get updated on receiving GRAT ARP.
CSCsy65347
QoS Profiles Per-User Bandwidth Contracts not restricting traffic.
CSCsy71960
1242 AP ignores primary controller to join a wrong controller.
CSCsy96551
Internal WLC-DHCP not sending out NAK.
CSCsz14243
Unable to enable the WLAN while the APs are joining.
CSCsz19203
Controller fails to respond at "SSHpmMainTask".
CSCsz40659
Need to reboot wireless controller for upgrade to work.
CSCsz79621
Inter frame delay causing reassembly issues, breaking EAP-TLS auth.
CSCsz80820
Primary Discovery Request not processed for AP priority scenario.
CSCsz86245
Cisco 5500 Series Controller: Add new usmdb APIs for SNMP optimization.
CSCsz87643
Management interface unreachable via different subnet.
CSCta01750
Controller unresponsive because of a deadlock on spamReceive task.
CSCta03016
Cisco 4404 Series Controller fails to respond in version 5.2.188.0.
CSCta06244
WLAN configuration not same when downloading backup config via TFTP.
CSCta09996
Sometimes LAP cannot join the controller through alternative port in port redundancy.
CSCta28666
Configuration on mesh link test RSSI output is incorrect.
CSCta40160
Controller dropping primary discovery request from an AP that has already joined the controller.
CSCta71448
Request to reduce the severity of the error msg: %APF-1-CHANGE_ORPHAN_PKT_IP
CSCta72642
Access point logging related command does not getting uploaded.
CSCta78236
Request to change min/max rogue RSSI rule values.
CSCta88592
WCS 6.0.132.0 does not show mesh AP Root in map view.
CSCta91358
Hybrid REAP gets locked up due to wedge input queue on radio interface.
CSCtb02136
AP 1252 with AP Groups and hybrid REAP do not broadcast SSID.
CSCtb16583
Static IP LAP cannot join a controller.
CSCtb20125
CCMP errors on key rotation.
CSCtb23682
When logged into Cisco 5500 Series Controller using Telnet, characters are shown multiple times.
CSCtb23924
HREAP: WebAuth user cannot log out after roaming.
CSCtb34971
Controller WiSM loading 3rd party certificate for web-auth disables HTTPS port 443.
CSCtb36010
Lightweight AP responds on port 22 when SSH is disabled.
CSCtb42260
Enabling broadcast forwarding versus multicast forwarding via CLI.
CSCtb45178
Insufficient memory/traceback on AP1130 and AP1232.
CSCtb52563
Controller running 4.2.205.0 is unresponsive at spam_CCM_decrypt+124
CSCtb56664
Remove Over The Air Provisioning (OTAP) in access points.
CSCtb58091
WLC CPU spike with emweb - controller not responding.
CSCtb61628
SNMP trap controls setting is not succeeded on 5.2.
CSCtb63297
File read errors in msglog file.
CSCtb64579
Wired Guest accessUser is not redirected to Webauth page after some time
CSCtb64994
Intermittent webadmin and webauth access on WiSM running 5.2.193.
CSCtb74239
WISM unresponsive on task sshpmMainTask System.
CSCtb82951
Controllers ARP table not updating after receiving gratuitous ARP update.
CSCtb92872
WiSM: System unresponsive - Task "cids-cl Task" taking too much CPU.
CSCtb93729
Authentication trap flag does not get saved on reboot.
CSCtb96750
AP Fallback causes client drop with HREAP.
CSCtc01947
Initial CAWAP Packets are sent to burned-in MAC by controller in HSRP.
CSCtc03575
Controller fails to redirect web authentication to an external server.
CSCtc05478
The packet: deb pm ssh-engine enable does not work.
CSCtc10068
1140 APs trying to join LWAPP controller.
CSCtc13474
Self IP Address displays error message: "No mobility record found for peer".
CSCtc14910
AP 1140 not joining WLC and logging tracebacks.
CSCtc15346
AP1252 fails to retransmit missing AMPDU packet in response to block acknowledgement.
CSCtc32748
Noise/Channel measurements not done on all DCA channels
CSCtc45090
Controller sends wrong MAC in ARP response, can cause mobility flapping
CSCtc49270
Clients can't be deleted from exclusion list if not present in association list.
CSCtc51089
The setting for WLAN security static-wep-key encryption does not get restored.
CSCtc57611
Delay in music on hold on 7925 with HREAP AP.
CSCtc85444
Controller locks up on SNMP task when pushing AP Group template from WCS.
CSCtc87690
Clients are mapped to the native VLAN of the H-REAP AP switchport trunk.
CSCtc97144
Fix 1800 second session timeout when H-REAP is in standalone mode.
CSCtd01611
Important TLS/SSL security update required.
CSCtd17116
Emergency image version shows up N/A.
CSCtd19928
WLC TACACS+ accounting sends large amount of white space.
CSCtd23497
1242 AP HREAP Mode unresponsive after %CAPWAP-5-CHANGED state to join.
CSCtd25303
Wrong message on GUI when controller image is upgraded while AP IDs downloading the image.
CSCtd26168
Incorrect source MAC in ARP request when WLC is in LAG mode.
CSCtd33864
WGBs are not shown as clients under Summary page.
CSCtd34312
5508 Web auth breaks with multicast MAC as gateway.
CSCtd46917
CPU ACL and service config priority change required for telnet.
CSCtd49103
AP in static address, uses wrong syslog and LEDs turn off for some seconds.
CSCtd61893
Rogue APs that are classified do not send trap when found missing
CSCtd62937
Show ap summary does not show the access point name.
CSCtd64049
AW:J:FFT: controller unresponsive when upgrading the access point.
CSCtd70053
Guest mobility anchoring fails when the guest roams between controllers.
CSCtd72234
4.2 Mesh MAC auth to external RADIUS has authenticator all zeros.
CSCtd73371
WLC Shared memory allocation failed after web passthrough enabled.
CSCtd74870
Massive DHCP flood/loop with NAC OOB - DHCP Proxy disabled.
CSCtd75094
AP fails to respond when clearing CAPWAP MGIDs for new client.
CSCtd82509
WLC fails to respond when performing findContextInfo+268.
CSCtd84522
Fiber port (gig3) does not create VLAN subinterfaces when bridging.
CSCtd86886
WiSM generates traceback in the msglog occasionally.
CSCtd90304
%MM-3-MEMORY_READ_ERROR: mm_mobile.c:464 Error reading mobility memory.
CSCtd92105
Reaper reset in DHCP task.
CSCtd99602
Wired Guest: DHCP required breaks web auth following session timeout.
CSCtd99659
SNMP Agent inserts nulls during mesh link test.
CSCte08090
AW: TFTP upload broken for packet capture to windows TFTP server.
CSCte18071
Inconsistent use of MAC addresses on controller.
CSCte24079
2106 LAN hangs after high load with duplex mismatch.
CSCte27052
WLC 6.0 - Inconsistency in AAA override feature.
CSCte38645
RADIUS Attribute NAS-Port(5) not included in Access-Request for Web-Auth.
CSCte39477
Web GUI: External Web Servers field needs to always be displayed.
CSCte43374
The WGB connection breaks under EAPoL logoff attack.
CSCte43508
The Cisco 5508 Series Controller DP unresponsive: buffer leak due to ARP storm.
CSCte45826
AP drops packets with SIP Based CAC- WPA2/AES or tcp-adjust-mss/WPA/TKIP.
CSCte55370
Controller unresponsive during ping of virtual interface.
CSCte55458
Web authentication: Web page takes a long time to display under heavy load.
CSCte64350
Cisco 5500 Series Controller encounters an internal membuffer system error.
CSCte73125
APs unable to join WiSM.
CSCte89891
Radio may stop transmitting beacons periodically.
CSCte92365
The fix for auto immune attacks does not cover for incorrectly formatted association request. Does not cover missing IE.
CSCte92886
4.2 Mesh controller memory leak in EAP framework.
CSCtf08553
Syslog not sent to server that is on same subnet as dynamic interface.
CSCtf11461
CPU ACL check for Outbound ICMP traffic should be removed on Cisco 5500 Series Controller.
CSCtf14098
Controller unresponsive at task sshpmMainTask under high web-auth load conditions.
CSCtf18016
WiSM hung unable to HTTP, HTTPs, Telnet or SSH. Only ping responded.
CSCtf23682
Cisco 5508 Series Controller- AP cannot join with Multicast MAC as gateway (checkpoint).
CSCtf27779
The command show tech from CAPWAP AP does not include CAPWAP information.
CSCtf28217
AP Unexpectedly joins the controller in bridge mode instead of local or H-REAP mode.
CSCtf34858
Client cannot transmit traffic if it reassociates to an AP within 20 seconds.
CSCtf36053
Any CPU ACL blocks service port DHCP offer.
CSCtf38685
Need source MAC in mentioned msglogs.
CSCtf39285
Cisco 5500 Series controller accepts a 4400 4.2.x.x image.
CSCtf39550
Traceback messages are seen on console logs for instruction *osapiReaper.
CSCtf51287
The command show exclusionlist does not display excluded clients it only displays disabled clients.
CSCtf53010
Controller unresponsive when 12 or more handsets associate to it.
CSCtf53344
LWAP DOS attack trap message does not record the source MAC address.
CSCtf55495
AP may crash during rate shift operation.
CSCtf57349
Controller only allows 47 access points to join on single port.
CSCtf69598
Memory leak in access point on CCKM failure.
CSCtf81266
APF-1-ROGUE_CLIENT_UPDATE_FAILED filling up syslog.
CSCtf91342
LDAP server does not respond for 15 minutes when an incorrect UN is used.
CSCtf94589
Access point MAC address discrepancy in aggressive load balancing packets.
CSCtf94857
OEAP does not respond to probes on 2.4 radio.
CSCtg09393
RRM TPC - Minimum power level assignment not working for levels below 4.
CSCtg14532
Controller PMKID debug output indicates "No valid PMKID" but PMKID works.
CSCtg19722
MFP - Cisco 4400 Series Controller running 6.0 version detects an MFP error of 5500 running 7.0.
CSCtg23396
The command show dhcp stats does not display when DHCP proxy is enabled.
CSCtg35661
XML error - while netusers configured.
CSCtg42627
CLI Allows "+" (Plus Sign) In AP Group Name Breaking WLC Config via GUI.
CSCtg42711
SANITY:5500 DP unresponsive: Hardware deadlock - all Packet Buffers in use
CSCtg45014
CT5508 - CAPWAP Control traffic has incorrect DSCP marking.
CSCtg52300
CPU Hog due to tight loop in case socket() or bind() fails.
CSCtg71658
AP power level reset to 0 when upgrading from 5.0 to 6.0.196.158.
CSCtg80756
Wrong BSSID in reassociation response during intracontroller roaming if CAC/CCKM fails.
CSCtg89404
Association response is sent with AID 0.
CSCtg94715
WLC unresponsive in dtlARPTask task.
CSCth11041
The command show cdp neighbors detail does not display correct duplex type.
CSCth12513
LAG fail-over does not work on CT5508.
CSCth19326
Country is not lexicographically ordered.
CSCth19362
The instruction cLApEntPhysicalIndex returns 2 always.
CSCth24422
Cisco Flex 7500 Series Controller-AP "TCP Adjust MSS" value changed to 21253 in WEB GUI.
CSCth25811
Mobility anchor configuration is not displayed on GUI after config upload.
CSCth26279
Controller unresponsive when accessing 0xfefefefc while logging.
CSCth27809
Running the CLI command renders the controller unresponsive.
CSCth27835
Bootloader output on console port is incorrect.
CSCth28860
Clarify support for third party chained certificates.
CSCth30456
Need to prevent from enabling VLAN support for OEAP.
CSCth31542
CT5508 7.0.98.0 - show ap crash-file does not include a timestamp.
CSCth31652
Image predownload breaks HREAP standalone.
CSCth31837
WLC as DHCP server for AP: CoS value incorrectly processed as a VLAN.
CSCth32078
Release note for WLC 7.0.98.0 references wrong WCS version.
CSCth36045
SNMP OID is not increasing in clcrRoamReasonReport table.
CSCth38520
OfficeExtend Docs Need to Remove the WPLUS License Requirement for 7.0.
CSCth41876
AMAC: MFP - Invalid MIC error due to held beacons on the radio.
CSCth42489
Multicast traffic stops after fast roaming - incorrect AP client count.
CSCth43373
5508 running 7.0 shows Field recovery images version as N/a
CSCth51156
Extracting custom web authentication tar package may fail on 5500 WLC
CSCth54834
Update WLC dot1x message logs to provide more useful information
CSCth56224
Clients with a static IP address may get stuck in DHCP_REQD state.
CSCth59030
The AP1140 fails for radio status check task.
CSCth60816
Mesh: A MAP fails to join the WLC again if the MAP switches a RAP.
CSCth66643
Docs need to specify that after successful web auth CPU ACL's apply.
CSCth67671
AP fallback IP is not displaying in GUI
CSCth68265
Key size support for third party certificates
CSCth68708
Clients are unable to get a DHCP offer from WLC internal DHCP scope
CSCth71298
*spamApTask4: %OSAPI-5-OSAPI_INVALID_TIMER: timerlib.c:543 Failed to return.
CSCth84839
Need to document that WGB does not support DirectStream feature.
CSCth90250
WLC does not bridge DHCP NAK to station and puts it into the RUN state.
CSCth90962
Document QoS 802.1p tagging blocks traffic on untagged interfaces.
CSCth93062
WLC may hang due to kernel Oops exception.
CSCth93134
Add additional Country vs. Regulatory Domain mappings.
CSCth93785
5508WLC generate duplicate ip add message & cause connectivity issue.
CSCth95130
Release notes for upgrade path on 7.0.98.0.
CSCth95827
QoS bandwidth limiting not supported on HREAP locally switch WLANs
CSCth95889
Web GUI Help: Session & DHCP Corrections to WLANs > Edit > Advanced Page.
CSCth96194
WLC kernel hang followed by flash issue; WLC not rebooting.
CSCth96617
Native VLAN configuration is not consistent in HREAP
CSCth97629
Wrong WLC version to support for 1260/3500 series APs.
CSCth97638
Mounting bracket information references 3500 instead of 1260 AP
CSCth97643
DHCP option 60 information is incorrect for 1260 series APs.
CSCth98074
Instruction clMeshNodeBatteryChargingState OID always returns '1'.
CSCti00211
Association fails on hybrid REAP access point when client changes SSID.
CSCti00488
ARP entry cannot be deleted permanently in controller.
CSCti02734
Radius CallStationIdType show undefined for ap-macaddr-ssid.
CSCti04259
Intermittent webauth page with HREAP local switching.
CSCti06406
Controller GUI does note have channel bandwidth selection for sniffer mode.
CSCti06835
Multicast packets stuck on radio after WLAN changes.
CSCti08253
Controller displays IP address 0.0.0.0 when it receives packets from console.
CSCti21621
Switch CAM table not updated after L2 roam.
CSCti23852
Downstream traffic degraded with OPEN environment.
CSCti26237
Mesh AP sends all primary discovery simultaneously; causes drops.
CSCti28117
Internal DHCP in a specific case returns "wrong IP address".
CSCti34667
Cisco 5508 controller drops TCP UDP packets.
CSCti35617
CSCti36424
7925 CCKM WPA2 failure: CCKM: Failed to validate REASSOC REQ IE.
CSCti36685
The value of ifSpeed in SNMP is incorrect in Cisco 5508 Controller.
CSCti40371
CSCtg96879 is not applicable to 7.0, remove from open caveats in RN.
CSCti41854
Controller 5500 does not use LAG_MAC when LAG is enabled.
CSCti44550
Low throughput when using block ACK with low MCS rates.
CSCti45379
Cisco 5508 Controller crashes when trying to shut the data ports one by one.
CSCti45717
PMK cache must be cleared upon reception of EAP-Failure.
CSCti50119
Controller running release 5.2 and higher releases config guides need to note about CISCO CAPWAP controller.
CSCti52933
When configuring Hybrid REAP with WLAN local switching, the static IP address bypasses 'DHCP required.'
CSCti53131
Controller unresponsive while executing the debug hreap aaa event command.
CSCti56136
Client stuck in DHCP required state if roaming with AAA override enabled.
CSCti58705
3500 series AP unresponsive - process CAPWAP client due to a memory error.
CSCti59414
Cisco 2500 Series Controller unable to add 72 mobility group member.
CSCti69852
Controller displays XML error if ACL is changed to "none" on WLAN.
CSCti75313
TKIP MIC errors on clients connected to AP3500 due to Raw 802.3 packets.
CSCti77984
LAG failover not working on Cisco 5508 Controller for FTP traffic.
CSCti78035
Request to fix a pop up error message when handling web authentication.
CSCti79172
Security baseline violation: backup restore on unit replacement.
CSCti81590
Controller time displays one hour offset from NTP server time.
CSCti83830
Passive clients are unable to pass traffic on Cisco 5500 Controller. This works fine on Cisco 4400 Series Controllers.
CSCti86618
AP3500 in local mode stops servicing allowed WLANs on 2.4 GHz.
CSCti89937
Containment of rogue access point and Rogue clients is ineffective.
CSCti91044
EAP state not cleared on RADIUS failover.
CSCti91944
Unified access points remove clients on maximum retries.
CSCtj02084
Cisco Flex 7500 Series Controller unresponsive on task emWeb when a running stress test.
CSCtj05569
WLC is not releasing the BIND for the first LDAP, the next user fails authentication.
CSCtj16960
Controller with of web authentication users may go unreachable or fail to redirect client.
CSCtj20267
Clients on service port VLAN cannot reach management interface.
CSCtj20996
Controller unresponsive when using a Bluetooth console serial adapter.
CSCtj21321
AP error due to process_execute; unexpected exception to CPUvector.
CSCtj21464
WLC data plane core fails to respond due to memory corruption.
CSCtj28483
C1130 core dump: Radio command cmd 21 (FF50,0,0) status 7F17.
CSCtj33453
Controller displays the error emWeb when running 6.0.199 in disabled client page.
CSCtj39193
Controller does not allow some rogue commands via TACACS+.
CSCtj45963
Controller RADIUS accounting stop packets are sent to the wrong AAA server.
CSCtj47041
AP unresponsive and core dumps due to low memory.
CSCtj47495
Cisco 5508 Controller forwards traffic on incorrect VLAN in AP group setup.
CSCtj53304
Wrong DTIM counter value.
CSCtj55556
AP names that contain spaces are lost in upgrade from 5.2 to 7.0.
CSCtj57012
When event driven RRM works, it changes global to custom channel set.
CSCtj57086
Persistent device avoidance does not work.
CSCtj57703
Subinterface not getting an IP address leads to high CPU and incorrect configuration.
CSCtj58064
CAPWAP encap ICMP reply packet from management interface uses burned-in MAC in HSRP.
CSCtj61260
11r IE should be removed from open auth reassociation response.
CSCtj61997
Controller unresponsive while running the command show ap eventlog.
CSCtj71342
Controller may fail to allow incoming traffic on ingress guest LAN interface.
CSCtj72131
Controller configuration for "avoid persistent non-wifi interference" missing.
CSCtj72400
Controller SNMP entPhysicalTable not returning all devices.
CSCtj73291
U-APSD state machine is stuck in "active mode" - trigger frames ignored.
CSCtj79172
WMM non-compliant U-APSD client does not "trigger" without TIM.
CSCtj82323
AP 1500 Global channel setting is changed to custom after reboot.
CSCtj84836
MC2UC (Directstream) stream stops due to IGMP query timeout.
CSCtj87294
RRM Start-Up mode is invoked under unknown conditions.
CSCtj88253
Cisco 5508 Series Controller does not allow RIPv2 updates.
CSCtj94377
Various access points unresponsive from block overrun or red zone corruption.
CSCtj97821
WLC does not use a consistent MAC address for forwarding traffic.
CSCtk05220
EAPoL key timer expires incorrectly.
CSCtk12832
ARP poisoning attack from wireless client on dynamic interface.
CSCtk17467
TACACS Authorization not allowing specific user roles full privileges.
CSCtk32374
AP unresponsive on CheckAdjustTransmitRate due to packet retries of WGB.
CSCtk34586
Anchor gateway failover breaks guest client traffic.
CSCtk34829
Some incomplete commands may cause the controller to be unresponsive.
CSCtk34919
IF-MIB::ifDescr changed in release 5.2 and later.
CSCtk53570
DP crash file contains incomplete backtrace.
CSCtk60177
Cisco 4402 Series Controller running version 7.0.98.0 is unresponsive with "Out of Memory" and "mwar_exit.crash".
CSCtk60361
Default CleanAir state is wrong if 11g is disabled.
CSCtk62719
Controller msglog shows Invalid ACL ID while debugging.
CSCtk83586
Controller unresponsive when executing task dtlArpTask.
CSCtk95891
ARP poisoning on 4400 platform using static IP address.
CSCtk99624
Cisco 5500 Series controller unresponsive- Software Failed while accessing the data located at :0x59.
CSCtl04377
DHCP flooded with redundant anchors and proxy disabled.
CSCtl07274
Web auth redirect fails with Hybrid REAP local switching.
CSCtl09302
Enabling password cleartext does not display some passwords in configuration file.
CSCtl22466
WLAN anchor information does not get saved correctly in configuration file.
CSCtl41344
Hybrid REAP access point rejects reassociation request without 802.11 authentication (Status 13).
CSCtl41711
Standalone hybrid REAP does not provide 11n access.
CSCtl46842
Client LEAR IP Address and L3 policies do not work together.
CSCtl50432
Controller is unresponsive at spectrumDataTask Reason: Reaper Reset.
CSCtl67176
WiSM unresponsive reaper reset: Task "dtlDataLowTask" missed software watchdog.
CSCtl71583
Memory leak sshpm, on sshencode line 252.
CSCtl74406
Controller forwards traffic to the wrong VLAN for the wired WGB clients.
CSCtn02943
Controller learns an incorrect MAC for Default Gateway of management VLAN.
CSCtn03174
The command clear arp does not clear all ARP entries in kernel.
CSCtn04253
Radio stops transmitting for several seconds under a high load.
CSCtn14126
ARP client protection breaks DHCP address reuse.
CSCtn16281
Mesh unresponsive on BVI restart by DHCP.
CSCtn17576
VLAN jumping is possible with WGB VLAN client support feature.
CSCtn26578
Cisco 5500 Series Controller unresponsive due to memory corruption.
CSCtn27632
H-REAP access point sends incorrect RADIUS service-type to backup server.
CSCtn37462
The command show net user summary Does Not Show Users Past 256 Entries.
CSCtn52948
HREAP - Reached max limit on the association ID for AP.
CSCtn54009
RLDP not restoring the serving channel causes the AP to reboot.
CSCtn73474
Memory corruption with SIP inspection enabled. Crash in PMALLOC_TRAILER.
CSCtn94220
Correct configuration guides concerning service-port IP addressing.
CSCtn99092
AP1130 unresponsive - IO memory corruption caused by bad 802.11 RX frames.
CSCto08803
Controller leaking unencrypted frames for WGB clients.
CSCtj81930
AP1140 reboot by Reason: Radio Not Beaconing for too long
WLC 6.0.196.158 Release Notes
Addendum Release Notes for Cisco Wireless LAN
Controllers and Lightweight Access Points for
Special Build 6_0_196_158
___________________________________________
Base Code: 6.0.196.0
Special Build: 6_0_196_158
ENGINEERING SPECIAL BUILD
6_0_196_158 is a build from 6.0.196.0, and it is an engineering special that resolves the following
additional caveats:
CSCta13941 - AP rejecting association request with status code 13
CSCtb02136 - AP with AP Groups and HREAP will not broadcast SSID
CSCtb20125 - CCMP errors on key rotation
CSCtb92872 - WiSM: System crash - Task "cids-cl Task" taking too much cpu:
CSCtc23789 - AP radio down - interface stuck in reset
CSCtc57611 - Delay in Music on Hold on 7925 with HREAP AP
CSCtc73503 - Radios are showing Tx power level 0
CSCtd28542 - WLC crash on emWeb due to AP config change
CSCtd97011 - Radio core dump: Neighbor Discovery frames stuck
CSCte19262 - Client Deauthenticated – “Unable to locate AP 00:00:00:00:00:00”
CSCte55219 - radio core dump due to large # of uplink frames in inprog queue
CSCte55458 - Web-Auth: Web page takes a long time to display under heavy load
CSCte62815 - 5508 not passing OSPF Multicast traffic
CSCte78472 - Invalid PHY rate returned on ADDTS response
CSCte81420 - Crash in process: "Dot11 driver "
CSCte89891 - AP doesn't transmit beacons
CSCte92365 - Auto Immune - AP side
CSCte93549 - The dot11a radio not able to pass traffic, tx queue getting filled.
CSCte96140 - Ethernet bridging breaks when the Ethernet interface of AP 1242 flapped
CSCtf23682 - 5508 - AP cannot join with Multicast MAC as gateway (checkpoint)
CSCtf27580 - Ethernet interface input queue wedge from broadcast/uniGRE traffic
CSCtf34858 - Clients unable to pass broadcast traffic
CSCtf63030 - Radio may get stuck in RESET or DOWN state
CSCtf69598 - Memory leak in AP on CCKM Failure
CSCtf94589 - AP mac address discrepency in aggressive load balancing packets.
*ENGINEERING SPECIAL USE DISCLAIMER*
The Engineering Special fix supplied herewith is a Temporary Software Module which has undergone
limited testing. This temporary software module is provided “AS-IS” without warranty under the terms
of the END USER LICENCSE FOR THIS PRODUCT. Please use this software at your own risk. The
intention for this code fix is for you to use in your production environment until a released version is
available.
Americas Headquarters
Cisco Systems, Inc., 170 West Tasman Drive, San Jose, CA 95134-1706 USA
© 2010 Cisco Systems, Inc. All rights reserved. 95134-1706 USA
