ITA Terms
Community Member
Technology
VoIP Applications
Description
A Route Group is a list of one or more gateways or ports on gateways that are seen as equal access. It is analogous to a trunk group in traditional PBX terminology. For instance, you may have two PRI circuits to the same carrier that can be used arbitrarily. A gateway (or a particular port on a gateway) can only be added to one Route Group.
