dwapstra
Route Summary Tool
https://cway.cisco.com/tools/RouteSummary/
Description
Have you ever looked for a tool that can convert thousands of routes to summarized routes?
This tool can help you minimize the number of routing entries in the network. The tool consolidates aggregate-able IPv4 and/or IPv6 routes into summary routes. The input should contain IPv4 or IPv6 addresses with maskbits notation (x.x.x.x/y or x.x.x.x::x/y) The IP addresses can be part of existing output in e.g. 'show ip route', no need to filter the output before using this tool.
 Example output:
Use Cases
This tool can be used to summarize routes from for example:
show ip route
show ip bgp
You can use the summarized routes to create aggregate route configuration in OSPF or BGP.
Guidelines
Upload show ip route or show ip bgp output to the tool and run the script to get summarized routes output. Data can be copied next to the "IPv4/IPv6 routes" section as shown with the red box. Click "summary" to generate the summarised routes.
craig pardo
Thanks, works well. Sometimes you'll need to reload the page because the summary doesn't produce any output.
Will there be improvements made to this tool?
Feature request would be to input a list of static routes and have it summarize the whole list. (some static routes may have additional cost applied)
Cristian Venegas
I tried accessing this URL over the public Internet, with no success. Are we looking to make this tool available to end customers?
Thank you.
Cristian Venegas
Technical Solutions Architect - Cisco
cmbhatt1115
There is a notice on the Route Summary Beta page that it's going to be retired on Sep 16, 2019. But no other details were given as to whether it will be replaced or completely removed or integrated into something other tool. Anyone have details around this?
thanks,
-=CB=-
Andrey Grechin
suhas bhoir
I have written a Python script using the Netaddr library and it is the most efficient and fastest of the previous Cisco Online Route Summary tool.
Sb
