Mohamed Alhenawy
Today I'm going to talk about SD-wan including SD-WAN advanced lab ,, first thing let's take a small brief about the SD_WAN.
What is SD-WAN?
SD-WAN is Software define wide area network and SD-WAN is key part of the technology of software-defined
networking . SDN is a centralized approach to network management which abstracts the underlying network infrastructure away from its applications ,SD-WAN has more advantage such as automation, simplification of operations, provisioning, monitoring, and smart troubleshooting.
Why SD-WAN solution ?
SD-WAN solution has major advantages but the most important of them is Cost and user experience let's imagine the connection with traditional wide area network (WAN) when users at the branch want to connect to applications hosted on servers in the data center through MPLS , look to cost & t-shoot , SD-WAN will reduce cost here because the solution Support for all typed of connections (4G, 5G, Broadband , MPLS that means you can select cheaper connection options for low-priority traffic and high cost for high-priority traffic.can help a branch router avoid loss, latency and jitter within the network, SD-WAN give you ease of management via your single pane of glass interface, Increasing bandwidth through the activate & backup links and dynamic load-balancing, Delivering faster cloud access by enabling direct internet access at the branch .As we are seeing today all business go with Software as a Service (SaaS) and Infrastructure as a Service (IaaS) across multiple clouds, IT departments are struggling with providing a satisfactory experience for business-critical applications, SD-WAN Delivering faster cloud access by enabling direct internet access .
How many planes in the Cisco SD-WAN solution ?
 Cisco SD-WAN solution contains four planes < Management plane , Control Plane , orchestration plane , Data plane > .
What is the components of cisco SD-WAN solution ?
The Cisco SD-WAN solution contains four key components responsible for each plane :
1-Cisco v-Manage :- Cisco V-manage is used to handle the management plane and represents the user interface of the solution.
2-Cisco v-Smart :- v-Smart is the brain of the solution and exists within the control plane,  v-Smart is the component responsible for enforcing these policies centrally and exchange the routing information.
3-Cisco v-Bond :- v-Bond is the orchestration plane responsible for on boarding the device into the SD-WAN fabric and Zero-Touch Provisioning process as well as first-line to authentication, v-Bond is responsible Network Address Translation (NAT) traversal.
4-  Edge routers :- Edge router is data plane and Edge routers are responsible for establishing the network fabric and forwarding traffic.
Let's start our SD_WAN LAB *
******* LAB TOPOLOGY *******
Initial Configuration for  DC & LAN Switches :
1- Management Switch
spanning-tree mode rapid-pvst
interface Port-channel10
description UPLINK-MGT-TRS
switch port trunk encapsulation dot1q
switchport mode trunk
interface Ethernet0/0
switchport access vlan 20
switchport mode access
spanning-tree port fast edge
interface Ethernet0/1
spanning-tree portfast edge
interface Ethernet0/2
interface Ethernet0/3
description UPLINK-TO-Vedge-1
no switchport
ip address 1.1.1.2 255.255.255.252
duplex auto
interface Ethernet1/0
interface Ethernet1/1
channel-protocol lacp
channel-group 10 mode active
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet2/0
description UPLINK-TO-Vedge-2
no switchport
ip address 2.2.2.2 255.255.255.252
duplex auto
interface Vlan20
ip address 20.20.20.100 255.255.255.0
2- Trans-Switch
description UPLINK-TO-VPN-0
switchport access vlan 200
duplex auto
duplex auto
duplex auto
no switchport
ip address 2.2.1.2 255.255.255.252
duplex auto
interface Vlan200
ip address 200.200.200.100 255.255.255.0
3- LAN-Switch-Site-1
interface Loopback1
description IPTPF
ip address 110.110.110.1 255.255.255.255
interface Loopback2
description Printer
ip address 110.110.110.2 255.255.255.255
interface Loopback3
description PC
ip address 110.110.110.3 255.255.255.255
ip address 172.16.1.2 255.255.255.252
ip address 172.16.2.2 255.255.255.252
4-LAN-Switch-Site-2
interface Loopback1
description IPTPF
ip address 120.120.120.1 255.255.255.255
interface Loopback2
description Printer
ip address 120.120.120.2 255.255.255.255
interface Loopback3
description PC
ip address 120.120.120.3 255.255.255.255
ip address 172.16.3.2 255.255.255.252
ip address 172.16.4.2 255.255.255.252
5-LAN-Switch-Site-3
interface Loopback1
description IPTPF
ip address 130.130.130.1 255.255.255.255
interface Loopback2
description Printer
ip address 130.130.130.2 255.255.255.255
interface Loopback3
description PC
ip address 130.130.130.3 255.255.255.255
ip address 172.16.5.2 255.255.255.252
6-LAN-Switch-Site-4
interface Loopback1
description IPTPF
ip address 140.140.140.1 255.255.255.255
interface Loopback2
description Printer
ip address 140.140.140.2 255.255.255.255
interface Loopback3
description PC
ip address 140.140.140.3 255.255.255.255
ip address 172.16.6.2 255.255.255.252
7-LAN-Switch-Site-5
 interface Loopback1
description IPTPF
ip address 150.150.150.1 255.255.255.255
interface Loopback2
description Printer
ip address 150.150.150.2 255.255.255.255
interface Loopback3
description PC
ip address 150.150.150.3 255.255.255.255
ip address 172.16.7.2 255.255.255.252
8-LAN-Switch-Site-6
 interface Loopback1
description IPTPF
ip address 160.160.160.1 255.255.255.255
interface Loopback2
description Printer
ip address 160.160.160.2 255.255.255.255
interface Loopback3
description PC
ip address 160.160.160.3 255.255.255.255
ip address 172.16.8.2 255.255.255.252
9-LAN-Switch-Site-7
interface Loopback1
description IPTPF
ip address 170.170.170.1 255.255.255.255
interface Loopback2
description Printer
ip address 170.170.170.2 255.255.255.255
interface Loopback3
description PC
ip address 170.170.170.3 255.255.255.255
ip address 172.16.10.2 255.255.255.252
ip address 172.16.9.2 255.255.255.252
Internet Service Provider
ip address 92.68.50.1 255.255.255.0
ip address 92.68.40.1 255.255.255.0
ip address 92.68.20.1 255.255.255.0
ip address 92.68.10.1 255.255.255.0
ip address 92.68.110.1 255.255.255.0
ip address 92.68.30.1 255.255.255.0
ip address 92.68.60.1 255.255.255.0
ip address 92.68.170.1 255.255.255.0
ip address 92.68.70.1 255.255.255.0
MPLS Service Provider
 SP-CORE
interface Loopback0
ip address 5.5.5.5 255.255.255.255
ip address 10.10.1.2 255.255.255.0
ip address 10.10.2.2 255.255.255.0
ip address 10.10.4.2 255.255.255.0
ip address 10.10.3.2 255.255.255.0
router ospf 50000
mpls ldp auto config area 0
router-id 5.5.5.5
network 5.5.5.5 0.0.0.0 area 0
network 10.10.0.0 0.0.255.255 area 0
router bgp 50000
bgp router-id 5.5.5.5
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor CORE peer-group
neighbor CORE remote-as 50000
neighbor CORE log-neighbor-changes
neighbor CORE update-source Loopback0
neighbor 1.1.1.1 peer-group CORE
neighbor 2.2.2.2 peer-group CORE
neighbor 3.3.3.3 peer-group CORE
neighbor 4.4.4.4 peer-group CORE
address-family ipv4
network 5.5.5.5 mask 255.255.255.255
redistribute connected
redistribute ospf 50000
neighbor CORE send-community both
neighbor CORE route-reflector-client
neighbor CORE next-hop-self
neighbor 1.1.1.1 activate
neighbor 2.2.2.2 activate
neighbor 3.3.3.3 activate
neighbor 4.4.4.4 activate
exit-address-family
address-family vpnv4
exit-address-family
mpls label protocol ldp
mpls ldp router-id Loopback0 force
mpls ldp neighbor 1.1.1.1 password CISCO
mpls ldp neighbor 2.2.2.2 password CISCO
mpls ldp neighbor 3.3.3.3 password CISCO
mpls ldp neighbor 4.4.4.4 password CISCO
mpls ldp neighbor 5.5.5.5 password CISCO
 SP-PE-1
ip vrf DC-S-1
rd 50000:1
route-target export 50000:1
route-target import 50000:1
route-target import 50000:70
route-target import 50000:170
route-target import 50000:2
route-target import 50000:10
route-target import 50000:110
route-target import 50000:60
route-target import 50000:20
route-target import 50000:30
ip vrf SITE-7-S-1
rd 50000:70
route-target export 50000:70
ip vrf SITE-7-S-2
rd 50000:170
route-target export 50000:170
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip vrf forwarding DC-S-1
ip ospf 1 area 0
ip address 10.10.1.1 255.255.255.0
ip vrf forwarding SITE-7-S-2
ip address 192.168.170.1 255.255.255.0
ip ospf 170 area 0
ip vrf forwarding SITE-7-S-1
ip address 192.168.70.1 255.255.255.0
ip ospf 70 area 0
router ospf 70 vrf SITE-7-S-1
redistribute bgp 50000 subnets
router ospf 170 vrf SITE-7-S-2
router ospf 1 vrf DC-S-1
router ospf 50000
mpls ldp autoconfig area 0
router-id 1.1.1.1
network 1.1.1.1 0.0.0.0 area 0
router bgp 50000
bgp router-id 1.1.1.1
neighbor 5.5.5.5 remote-as 50000
neighbor 5.5.5.5 update-source Loopback0
address-family ipv4
network 1.1.1.1 mask 255.255.255.255
neighbor 5.5.5.5 activate
neighbor 5.5.5.5 send-community both
neighbor 5.5.5.5 next-hop-self
exit-address-family
exit-address-family
address-family ipv4 vrf DC-S-1
redistribute static
redistribute ospf 1
neighbor 192.168.1.2 remote-as 65000
neighbor 192.168.1.2 activate
exit-address-family
address-family ipv4 vrf SITE-7-S-1
redistribute static
redistribute ospf 70
neighbor 192.168.70.2 remote-as 65007
neighbor 192.168.70.2 activate
exit-address-family
address-family ipv4 vrf SITE-7-S-2
redistribute static
redistribute ospf 170
neighbor 192.168.170.2 remote-as 65007
neighbor 192.168.170.2 activate
exit-address-family
ip forward-protocol nd
ip http server
ip http secure-server
 SP-PE-2
ip vrf DC-S-2
rd 50000:2
route-target export 50000:2
ip vrf SITE-1-S-1
rd 50000:10
route-target export 50000:10
ip vrf SITE-1-S-2
rd 50000:110
route-target export 50000:110
ip cef
no ipv6 cef
cts logging verbose
redundancy
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip vrf forwarding DC-S-2
ip address 192.168.2.1 255.255.255.0
ip ospf 2 area 0
ip address 10.10.2.1 255.255.255.0
ip vrf forwarding SITE-1-S-1
ip address 192.168.10.1 255.255.255.0
ip ospf 10 area 0
ip vrf forwarding SITE-1-S-2
ip address 192.168.110.1 255.255.255.0
ip ospf 110 area 0
router ospf 2 vrf DC-S-2
router ospf 10 vrf SITE-1-S-1
router ospf 110 vrf SITE-1-S-2
router ospf 50000
router-id 2.2.2.2
network 2.2.2.2 0.0.0.0 area 0
router bgp 50000
bgp router-id 2.2.2.2
address-family ipv4
network 2.2.2.2 mask 255.255.255.255
exit-address-family
exit-address-family
address-family ipv4 vrf DC-S-2
redistribute ospf 2
neighbor 192.168.2.2 remote-as 65000
neighbor 192.168.2.2 activate
exit-address-family
address-family ipv4 vrf SITE-1-S-1
redistribute ospf 10
neighbor 192.168.10.2 remote-as 65001
neighbor 192.168.10.2 activate
exit-address-family
address-family ipv4 vrf SITE-1-S-2
redistribute ospf 110
neighbor 192.168.110.2 remote-as 65001
neighbor 192.168.110.2 activate
exit-address-family
control-plane
 SP-PE-3
ip vrf SITE-6-S-1
rd 50000:60
route-target export 50000:60
ip cef
no ipv6 cef
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip vrf forwarding SITE-6-S-1
ip address 192.168.60.1 255.255.255.0
ip ospf 60 area 0
ip address 10.10.3.1 255.255.255.0
router ospf 60 vrf SITE-6-S-1
router ospf 50000
router-id 3.3.3.3
network 3.3.3.3 0.0.0.0 area 0
router bgp 50000
bgp router-id 3.3.3.3
address-family ipv4
network 3.3.3.3 mask 255.255.255.255
exit-address-family
exit-address-family
address-family ipv4 vrf SITE-6-S-1
redistribute ospf 60
neighbor 192.168.60.2 remote-as 65006
neighbor 192.168.60.2 activate
exit-address-family
no ip http server
no ip http secure-server
control-plane
 SP-PE-4
ip vrf SITE-2-S-1
rd 50000:20
route-target export 50000:20
ip vrf SITE-3-S-1
rd 50000:30
route-target export 50000:30
ip cef
ipv6 cef
interface Loopback0
ip address 4.4.4.4 255.255.255.255
ip vrf forwarding SITE-2-S-1
ip address 192.168.20.1 255.255.255.0
ip ospf 20 area 0
ip address 10.10.4.1 255.255.255.0
ip vrf forwarding SITE-3-S-1
ip address 192.168.30.1 255.255.255.0
ip ospf 30 area 0
router ospf 20 vrf SITE-2-S-1
router ospf 30 vrf SITE-3-S-1
router ospf 50000
router-id 4.4.4.4
network 4.4.4.4 0.0.0.0 area 0
router bgp 50000
bgp router-id 4.4.4.4
address-family ipv4
network 4.4.4.4 mask 255.255.255.255
exit-address-family
exit-address-family
address-family ipv4 vrf SITE-2-S-1
redistribute ospf 20
neighbor 192.168.20.2 remote-as 65002
neighbor 192.168.20.2 activate
exit-address-family
address-family ipv4 vrf SITE-3-S-1
redistribute ospf 30
neighbor 192.168.30.2 remote-as 65003
neighbor 192.168.30.2 activate
exit-address-family
control-plane
V-Manage
Welcome to Viptela CLI
admin connected from 127.0.0.1 using console on Vmanage
config
system
host-name Vmanage
system-ip 10.10.10.101
site-id 100
admin-tech-on-failure
sp-organization-name "Cisco-ARCH"
clock timezone Africa/Cairo
vbond 200.200.200.103
aaa
auth-order local radius tacacs
usergroup basic
task system read write
task interface read write
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
logging
disk
enable
ntp
server 200.200.200.100
version 4
prefer
exit
vpn 0
interface eth0
description Connect-To-VPN-0-TRNS
ip address 200.200.200.101/24
ipv6 dhcp-client
tunnel-interface
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service netconf
allow-service ntp
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 200.200.200.100
vpn 512
interface eth1
ip dhcp-client
no shutdown
ip route 0.0.0.0/0 192.168.205.2
V-Smart
system
host-name v-smart
system-ip 10.10.10.102
site-id 100
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
usergroup tenantadmin
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
vpn 0
interface eth0
ip address 200.200.200.102/24
ipv6 dhcp-client
tunnel-interface
allow-service all
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service stun
no shutdown
vpn 512
interface eth1
ip address 20.20.20.102/24
no shutdown
ip route 0.0.0.0/0 20.20.20.100
V-Bond
 system
host-name vbond
system-ip 10.10.10.103
site-id 100
no route-consistency-check
vbond 200.200.200.103 local
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
authentication-type ah-sha1-hmac sha1-hmac
vpn 0
interface ge0/0
ip address 200.200.200.103/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
no allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
no allow-service sshd
no allow-service netconf
no allow-service ntp
no allow-service ospf
no allow-service stun
allow-service https
no shutdown
vpn 512
interface eth0
ip address 20.20.20.103/24
no shutdown
Open Vmanage through GUI and Generate the CA and Add the controllers include V-samrt & V-bond
Access to the ip address of the vmanage : https://192.168.205.151/#/app/config/devices/controller and Add the V-smart Controller
Configure ----> Device -----> Controller ----->add controller -----> V-samrt  -----> write ip address -----> save
Configure ----> Device -----> Controller ----->add controller -----> V-bond  -----> write ip address -----> save
Generate the certificate for the V-smart & V-Bond and install on the vmanage
Certification Installation - vManage:
- Go to shell mode---> vshell
- Generate RK ---> openssl genrsa -out ROOTCA.key
- Generate ROOTCA.pem
openssl req -x509 -new -nodes -key ROOTCA.key -sha256 -days 365 \
-subj "/C=US/ST=Egypt/L=Cairo/O=Cisco-ARCH/CN=Cisco-ARCH" \
-out ROOTCA.pem
-Copy the contents of ROOTCA.pem by below steps:
vManage cli --> vshell --> cat ROOTCA.pem
-Change the Controller Certificate Authorization to use Enterprise Root Certificate in vManage GUI -->Controller Certificate Authorization -->and paste the copy contents here.
- CREATING CSR FOR vMANAGE:
vManage GUI --> Config --> Cert --> Controllers --> vManage --> Generate CSR
Copy the contents of CSR -- > vshell --> ls (to check vmanage.csr file is there or not) if not we need to create it by vim vmanage.csr and paste the contents from step 6 using below method.
-Create a file in vManage vshell named "vim vmanage.csr"
Press "i" to insert.
Press Esc, and type :wq and press Enter. (to save file in vim)
- vManage --> vshell --> cat vmange.crt
copy the contents .. go to vmange GUI --> cert --> controllers --> install cert -- and paste it and install.
Certification Installation - v-Bond:
-  Add vBond to control plane from vManage GUI and generate certificate.
- Copy the generated certificate:
Create a file in vManage vshell named "vim vbond.csr"
- Use below command to create vbond.crt.
openssl x509 -req -in vbond.csr \
-CA ROOTCA.pem -CAkey ROOTCA.key -CAcreateserial \
-out vbond.crt -days 365 -sha256
- In vmange --> vshell --> ls (You will see vbond.crt) --> cat vbond.crt
copy the content of vbond.crt
Go to vManage GUI --> Certificates --> Controllers --> Install Certificate (Paste it here) and click install.
Certification Installation - v-Smart:
- Add v-Smart to control plane from vManage GUI and generate certificate.
Create a file in vManage vshell named "vim vsmart.csr"
openssl x509 -req -in vsmart.csr \
-out vsmart.crt -days 365 -sha256
In vmange --> vshell --> ls (You will see vbond.crt) --> cat vsmart.crt
copy the content of vsmart.crt
Once Finish start the process to upload Wan Edge list Serial number to V-Manage
Initial Configuration for V-Edges
Edge-1
ip address 192.168.1.2 255.255.255.0
ip address 92.68.1.2 255.255.255.0
no ip address
shutdown
ip address 1.1.1.1 255.255.255.252
ip ospf 65000 area 0
router ospf 65000
redistribute connected subnets
redistribute static subnets
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd!
control-plane
Edge-2
ip address 192.168.2.2 255.255.255.0
ip address 92.68.2.2 255.255.255.0
ip ospf 200 area 0
no ip address
shutdown
ip address 2.2.1.1 255.255.255.252
router ospf 65000
router ospf 200
V-Edge-3
system
host-name vedge3
system-ip 10.10.10.3
site-id 10
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$VCWr0lO6AuUXq5Lq$pB5Sbj2Y3aThQH8mB1dxJ48MeoyFsnzfy5Yw48tcOTF8hCbbRDc/jWDuNMLL2UgFrkorVRwgzh8rJa/pWis9b.
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
interface ge0/0
ip address 192.168.10.2/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 192.168.10.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-4
system
host-name vedge4
system-ip 10.10.10.4
site-id 10
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$kdYaJgEKgTE1lYPg$790vxuzZsntcANPeszeY3n5zEHki3nNAgHvk1w4QIJfL/8Lc2.iyrqfJThY0rdGOBWdzhyoU8ZK3QjE0ljnGc/
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
interface ge0/0
ip address 192.168.110.2/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 192.168.110.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-5
 system
host-name vedge5
system-ip 10.10.10.5
site-id 20
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$NHI7YW/5h5RP7Gl1$EawSHFWSCGTLuL9A.zINchu0MVeb4ZE/QkDugZJAIt3E9hpKrY9Szm0L5cV6w6UzuIw5gUTGJ7WzU6ISv7yVU0
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
interface ge0/0
ip address 192.168.20.2/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 192.168.20.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-6
system
host-name vedge6
system-ip 10.10.10.6
site-id 20
organization-name"Cisco-ARCH"
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$OW9PFx22kGwp07mL$7.zL8RFr2/soNnki9mVnzAFMowdJhE00j632EXVVZxc/zcIXLHaSOTwQX13GhhZ.eHxiSyBs6BFt4v2yweCXO0
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
router
ospf
timers spf 200 1000 10000
area 0
interface ge0/1
exit
exit
interface ge0/1
ip address 92.68.20.2/24
tunnel-interface
encapsulation ipsec
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 92.68.20.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-7
system
host-name vedge7
system-ip 10.10.10.7
site-id 30
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$Wzq28VHh8I.vHQY5$2hp2UpSLT3IZ1Zx16nudgD/uS789TZTsqcfSi/c1yi0RgNXjT/LQBFS0YxxTxTqusOnK.OWIxvxOL91BM/EOU.
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
interface ge0/0
ip address 192.168.30.2/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 192.168.30.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-8
system
host-name vedge8
system-ip 10.10.10.8
site-id 40
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$.KEyw/4ylWbWRBHf$CHYbWd4rp6DcMAHDw0mVcTOc0gLhyC7bO7rIhoijsYNsVZ4THenElrEG0K3jd2F7tSr3RZaHcRhSlaoC3lMhm0
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
interface ge0/1
ip address 92.68.40.2/24
tunnel-interface
encapsulation gre
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 92.68.40.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-9
system
host-name vedge9
system-ip 10.10.10.9
site-id 50
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$e9MOUVqPdEygM8Ne$tQF0SSmNolqdv9UsBFYicTzhfxtLQzsZZ0xkcv574O3ZSk62Lydnx7KTje8y2v.HVapxxxPNQXR5etxSjmx2u0
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
interface ge0/1
ip address 92.68.50.2/24
tunnel-interface
encapsulation gre
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 92.68.50.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-10
system
host-name vedge10
site-id 60
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$rrdeQ5D9nmbVhka9$KzIcOifpliu6QQMIDD2lfFO4RjTN0ARsEpuPPryMQGT6SOpmECFnYXZZ2IDK9AlpGbzLP/n7GzjTPYYOhUXMa/
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
interface ge0/0
ip address 192.168.60.2/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 192.168.60.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-11
system
host-name vedge11
system-ip 10.10.10.11
site-id 70
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$0Yk6/BKcz/DUuXXo$k2o2vhy8SZuY9dXnUlHdF.IL.SgAtt5yvcX5UGq2L9OFuYaleMTkpvM.FeqFyAXR9Qh1U2QMvvtyVgCB1fIeD.
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
router
ospf
area 0
interface ge0/0
exit
exit
interface ge0/0
ip address 192.168.70.2/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 192.168.70.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
V-Edge-12
system
host-name vedge12
system-ip 10.10.10.12
site-id 70
aaa
usergroup basic
usergroup netadmin
usergroup operator
task system read
task interface read
task policy read
task routing read
task security read
user admin
password $6$jH1.AEHiGCFi9f.p$B8Thld1CTDMrrTZf.lnsvNvGCKi6uAw.w6jmQRh6ML3.hs/y4O1XlZH4wC0RDGGmXwiZJWQxaEtFaAHV0nHlE.
logging
disk
enable
ntp
version 4
prefer
exit
omp
no shutdown
graceful-restart
advertise connected
advertise static
security
ipsec
vpn 0
interface ge0/0
ip address 192.168.170.2/24
ipv6 dhcp-client
tunnel-interface
encapsulation ipsec
allow-service all
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service stun
allow-service https
no shutdown
ip route 0.0.0.0/0 192.168.170.1
vpn 512
interface eth0
ip dhcp-client
ipv6 dhcp-client
no shutdown
Verification reachability  to Controllers :
vedge3# ping 200.200.200.103
Ping in VPN 0
PING 200.200.200.103 (200.200.200.103) 56(84) bytes of data.
64 bytes from 200.200.200.103: icmp_seq=1 ttl=59 time=39.1 ms
64 bytes from 200.200.200.103: icmp_seq=2 ttl=59 time=44.8 ms
--- 200.200.200.103 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 39.106/41.976/44.846/2.870 ms
vedge3# ping 200.200.200.102
Ping in VPN 0
PING 200.200.200.102 (200.200.200.102) 56(84) bytes of data.
64 bytes from 200.200.200.102: icmp_seq=1 ttl=59 time=18.6 ms
64 bytes from 200.200.200.102: icmp_seq=2 ttl=59 time=10.8 ms
--- 200.200.200.102 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2001ms
rtt min/avg/max/mdev = 10.822/16.336/19.555/3.920 ms
vedge3# ping 200.200.200.101
Ping in VPN 0
PING 200.200.200.101 (200.200.200.101) 56(84) bytes of data.
64 bytes from 200.200.200.101: icmp_seq=1 ttl=59 time=22.5 ms
64 bytes from 200.200.200.101: icmp_seq=2 ttl=59 time=25.2 ms
vedge4# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
vedge5# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
vedge6# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
vedge7# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
vedge8# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
vedge9# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
vedge10# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
vedge11# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
vedge12# ping 200.200.200.103
Ping in VPN 0
Ping in VPN 0
Ping in VPN 0
Stay tuned for part ||  , Press Star if it's helpful for your knowledge !
***** I hope that has been informative for you and thank you *****
Mohamed Alhenawy
CCIE#60453
navchoud
Hi @Mohamed Alhenawy great work. Can you share me the eve-ng lab or perhaps dcloud lab if you have
Mohamed Alhenawy
Hi @navchoud
Thanks Mate , yes sure please share your mail by DM .
rkiplangat
Hi Mohamed, thanks for sharing. kindly share the eve-ng lab
rono
nil13247tw
Hi  Mohamed Alhenawy
Can you share the files eve-ng please?
Thank you
wayne253
Hi Mohamed.
Many thanks for this can you please share the EVE-NG files.
Wayne
