TCC_2
Community Member
Core Issue
These are some of the reasons these issues occur:
  • Clocking problems
  • Faulty cabling
  • A TELCO line is down.
  • Keepalives are not sent by a remote router.
  • Noisy line
Resolution
For a workaround, perform these steps:
  1. Issue the Router # sh interfaces serial < ID > command in EXEC mode.
  2. From the output, check the first line. This gives the interface status.
For additional information, refer to table 15-1 in the Serial Lines: show interfaces serial Status Line Conditions section of Troubleshooting Serial Line Problems.
