kangupta
Ideally, the LWAPP access points are plug and play devices. Once you plug a LWAPP AP into a switchport, assuming all the other network config is in place (AP and WLC on same vlan, or AP is able to learn WLC via DHCP or DNS), it should register with the controller just fine.
"sh version" on the AP will have a "k9w8" in it instead of a "k9w7" which stands for autonomous.
Lightweight/controller based/capwap/lwapp image:
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(23c)JZ, RELEASE SOFTWARE (fc1) c1130-k9w8-mx.124-23c.JZ
Autonomous/IOS/Standalone image:
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)c1140-k9w7-mx.124-21a.JY
You cannot access the light weight AP via telnet, ssh or web directly. You can only make changes to it via the controller once it registers to it.
It is sometimes necessary to make config changes statically on the AP before it registers to the controller; e.g. assign static address, an ip gateway or tell it which controller to join to. This can be done with cli commands via the console port, which are unlike the IOS commands that we are used to.
1. To see all static config on the AP:
AP0022.9090.e859#sh capwap ip config
LWAPP Static IP Configuration
2. Static config -
AP0022.9090.e859#capwap ap ip address 192.168.1.2 255.255.255.0
AP0022.9090.e859#capwap ap ip default-gateway 192.168.1.1
Telling the AP the controller to join-
AP0022.9090.e859#capwap ap controller ip address 192.168.1.10
IP Address         192.168.1.2
IP netmask         255.255.255.0
Default Gateway    192.168.1.1
Primary Controller 192.168.1.10
To view the AP private-config:
AP0022.9090.e859#show capwap client config
configMagicMark         0xF1E2D3C4
chkSumV2                4204
chkSumV1                33089
swVer                   7.2.110.0
adminState              ADMIN_ENABLED(1)
name                    AP0022.9090.e859
location                default location
group name
mwarName
mwarIPAddress           192.168.1.10
mwarName
mwarIPAddress           0.0.0.0
mwarName
ssh status              Disabled
Telnet status           Disabled
numOfSlots              2
spamRebootOnAssert      1
spamStatTimer           180
randSeed                0x5B3B
transport               SPAM_TRANSPORT_L3(2)
transportCfg            SPAM_TRANSPORT_DEFAULT(0)
initialisation          SPAM_PRODUCTION_DISCOVERY(1)
ApMode                  Local
ApSubMode               Not Configured
AP Rogue Detection Mode Enabled
OfficeExtend AP         [0] Disabled
OfficeExtend AP JoinMode[0] Standard
Discovery Timer         10 secs
Heart Beat Timer        30 secs
Led State Enabled       1
Primed Interval         0
AP ILP Pre-Standard Switch Support Disabled
AP Power Injector Disabled
Infrastructure MFP validation Disabled
Configured Switch 1 Addr 192.168.75.48
Configured Switch 2 Addr 192.168.75.52
non-occupancy channels:
Ethernet (Duplex/Speed) auto/auto
3. To clear the config-
AP0022.9090.e859#clear capwap ap ip address
AP0022.9090.e859#clear capwap ap ip default-gateway
AP0022.9090.e859#clear capwap ap hostname
AP0022.9090.e859#clear capwap ap controller ip address
To clear the AP private config-
AP0022.9090.e859#clear capwap private-config
4. Normally, if the AP cannot find a controller to join, it will automatically reboot.
To prevent it from rebooting,-
AP0022.9090.e859#debug capwap cli no-reload
5. Prior to configuring the AP:
Before the Access Point will allow configuration changes, it is first necessary to enter the following debug command:
AP0022.9090.e859#debug capwap console cli
This command is meant only for debugging/troubleshooting
Any configuration change may result in different
behavior from centralized configuration.
CAPWAP console CLI allow/disallow debugging is on
6.To upgrade the rcv image on the AP-
archive download-sw /overwrite /force-reload tftp://<TFTP SERVER>/<file name>
e.g- archive download-sw /overwrite /force-reload tftp://192.168.5.12/ap3g1-rcvk9w8-tar.124-23c.JA3.tar
default password: Cisco
The AP should boot up with the lightweight code; "sh version" on the AP will have a "k9w8" in it instead of a "k9w7" which stands for autonomous.
6. Debug commands to monitor the discovery process:
AP0022.9090.e859#debug ip udp
To view the AP detail (controller ip, operational state, software version):
AP0022.9090.e859#show capwap client rcb
AdminState                  :  ADMIN_ENABLED
SwVer                       :  7.2.110.0
NumFilledSlots              :  2
MwarName                    :  5508-5
MwarApMgrIp                 :  192.168.75.48
MwarHwVer                   :  0.0.0.0
ApMode                      :  Local
ApSubMode                   :  Not Configured
OperationState              :  UP
CAPWAP Path MTU             :  1485
LinkAuditing                :  disabled
AP Rogue Detection Mode     :  Enabled
AP Tcp Mss Adjust           :  Disabled
Band Direct                 :  Enabled
Predownload Status          :  None
Auto Immune Status          :  Disabled
RA Guard Status             :  Enabled
Efficient Upgrade State     :  Disabled
Efficient Upgrade Role      :  None
TFTP Server                 :  Disabled
802.11bg(0) Radio
  GPR Period                : 10
  Beacon Period             : 100
  DTIM Period               : 0
  World Mode                : 1
  VoceraFix                 : 0
  Fragmentation Threshold   : 2346
  Current Tx Power Level    : 7
  Current Channel           : 6
802.11a(1) Radio
  GPR Period                : 10
  Beacon Period             : 100
  DTIM Period               : 0
  World Mode                : 1
  VoceraFix                 : 0
  Current Tx Power Level    : 0
  Current Channel           : 165
NOTE - For older APs,"capwap" will not work; in that case replace the "capwap" keyword in all the above commands with "lwapp"
Rashmy Abraham
What does RCB stand for?
Rashmy
nikolaraicevic
Community Member
Good post. I used them for configuring 1242g, but with a little addition.
1242g trying to resolve DNS name of default name of WLC controler.
This command solve this.
capwap ap primary-base WLC-Name 192.168.1.10
Also it could be done with putting A record on local DNS of WLC name.
Andy
Visitor
Cheers mate helped me a lot 🙂
