TCC_2
Level 10
Level 10
Core issue
A switch is showing only the switch: prompt would indicate that the boot path is not set to look for the correct IOS image, or there is no IOS image on the switch.
Resolution
Perform the following steps:
  • Determine if there is an IOS image on the switch.
  • If there is an IOS image, set the boot path to look at that IOS image.
    Follow these steps for setting the boot path to look at the IOS image:
      • At the switch: prompt, successively enter each of the following commands:
      • flash_init
        load_helper
        dir flash:
        !--- Look for a file that starts with
        !--- c3500XL-c3h2s-mz-120.???????, also known as the image name.
        set BOOT flash:image name
        !--- Enter.
        boot
    These steps should get the switch up and running if a valid IOS image exists on the switch.
    If this does not work, refer to Software Recovery.
    emanuell1613
    this don't solve my problem
    Rich R
    And what exactly is your problem @emanuell1613 ?
    What troubleshooting steps have you taken and what were the results?
    What model of switch are you working with?
