mavespig
Level 8
Level 8
Router# show dsl interface atm0
Alcatel 20150 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT)
ITU STD NUM:     0x01                            0x1
Vendor ID:       'ALCB'                          'ALCB'
Vendor Specific: 0x0000                          0x0000
Vendor Country:  0x00                            0x0F
Capacity Used:   85%                             98%
Noise Margin:    13.5 dB                          7.0 dB
Output Power:     9.5 dBm                        12.0 dBm
Attenuation:      1.5 dB                          3.5 dB
Defect Status:   None                            None
Last Fail Code:  None
Selftest Result: 0x00
Subfunction:     0x15
Interrupts:      5940 (0 spurious)
PHY Access Err:  0
Activations:     1
SW Version:      3.670
FW Version:      0x1A04
                 Interleave             Fast    Interleave              Fast
Speed (kbps):             0             8128             0               864
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             0                 7
Header Errors:            0                0             0                 2
Bit Errors:               0                0
BER Valid sec:            0                0
BER Invalid sec:          0                0
Acceptable values for show dsl interface:
- NOISE MARGIN: The higher the better - [8-13] Average - [14-22] Good - [23-28] Excellent
Under 8dB the line will have flaps, loss of synchronization, possibly no synchronization at all.
- ATTENUATION: The lower the better - [20-30] Excellent - [30-40] Good - [40-60] Average
Over 60, the attenuation is too high and you will have issues
