TCC_2
Community Member
Core Issue
Installation of the Aironet Client Utility (ACU) has failed.
Resolution
If your attempt to install ACU fails, follow these steps:
  1. Close any Windows programs that are running.
  2. Select Start > Run, and enter the path to the installed ACU files (the default location is C:\Program Files\Cisco Aironet\setup.exe), and click OK. The Welcome screen for the Aironet Client Utility setup maintenance program appears.
  3. Select Repair and click Next. The Setup Complete screen appears.
  4. If your computer needs to be rebooted, select Yes, I want to restart my computer now or No, I will restart my computer later.
    Note: If you are prompted to reboot your computer, Cisco recommends that you select the Yes, I want to restart my computer now option.
  5. Click Finish. The repair is complete. All of the selections you made during the previous installation are maintained.
Problem Type
Install
Upgrade
Products
WLAN adapters (wireless card) / ACU (Aironet Client Utility)
Client OS Type
Windows
