TCC_2
Community Member
Core Issue
The bridge loop is created when you have two paths back to the same location.
Resolution
The bridge loop is created when you have two paths back to the same location. This may be possible if you are connecting the wireless bridge onto the same hub or switch and creating a loop through the antenna interface.
Problem Type
Error message
Products
Bridge
