Cisco Document Team
Community Manager
Community Manager
The Cisco Document Team has posted an article.
This document describes how to identify, collect useful logs, and troubleshoot problems that can occur with Port Flaps on Catalyst 9000 switches.
Know of something that needs documenting? Share a new document request to doc-ic-feedback@cisco.com
Your input helps! If you find an issue specific to a document, please let us know. Remember to provide as much detail as possible when submitting a request or feedback on an existing document including information regarding the section, area, or issue you had with the document and what could be improved.
You can provide feedback in a few ways:
See How Cisco TAC is transforming documentation and simplifying self-service in this blog
Leo Laohoo
TDR works with switches running classic IOS bug, however, TDR is broken (does not work) with IOS-XE (CSCwd97177).  The output is totally unreliable and incorrect.
Bug affects switches running 16.X.X and 17.X.X.
(Above)  Pair A & B distance is "0".(Above)  Pair A & B distance is "0".(Above)  Pair "A" distance is (significantly) more than Pairs B, C and D.(Above)  Pair "A" distance is (significantly) more than Pairs B, C and D.
